Previous in Forum: Circuit Diagrams of Refrigerant Air Dryers   Next in Forum: RST 25 Phase Failure Under & Over Voltage Relay
Difference Between Converter and Inverter?
10/07/2010 4:59 AM
What are differences between the electrical converter and the electrical inverter?
Good Answers: 29
Re: Difference Between Converter and Inverter?
10/07/2010 8:32 AM
From the late nineteenth century through the middle of the twentieth century, DC-to-AC power conversion was accomplished using rotary converters or motor-generator sets (M-G sets). In the early twentieth century, vacuum tubes and gas filled tubes began to be used as switches in inverter circuits. The most widely used type of tube was the thyratron.
The origins of electromechanical inverters explain the source of the term inverter. Early AC-to-DC converters used an induction or synchronous AC motor direct-connected to a generator (dynamo) so that the generator's commutator reversed its connections at exactly the right moments to produce DC. A later development is the synchronous converter, in which the motor and generator windings are combined into one armature, with slip rings at one end and a commutator at the other and only one field frame. The result with either is AC-in, DC-out. With an M-G set, the DC can be considered to be separately generated from the AC; with a synchronous converter, in a certain sense it can be considered to be "mechanically rectified AC". Given the right auxiliary and control equipment, an M-G set or rotary converter can be "run backwards", converting DC to AC. Hence an inverter is an inverted converter.
That's a Wiki blurp but I hope it answers your question. I Hate to plaigerize just a little bit less than I hate to type.
10/07/2010 9:05 AM
I don't think it's plagiarism if you cite the source, which you did. I know what you mean about typing though
02/27/2011 1:08 PM
Inverter is a kind of Converter.."All inverters are converters but all converters are not inverters"
mscs
Register to Reply 3 comments
Mikerho (1); MSCS (1); RDGRNR (1)
