Previous in Forum: Fan's Bearing   Next in Forum: Cooling and Humidity Control
How to Size a Chiller Capacity for a Heat Exchanger
10/07/2010 11:57 AM
Please let me know what are the formula and parameters I need to size the capacity of a chiller to be used as a coolant in a shell & tube heat exchanger.
Pathfinder Tags: capacity chiller heat exchanger
Good Answers: 29
Re: How to Size a Chiller Capacity for a Heat Exchanger
10/07/2010 2:53 PM
Here are some calculators. I suggest you use them, if for nothing else, to learn what variables you need to define to expect any worthwhile response.
