Previous in Forum: Purpose of WPS   Next in Forum: VRV & VRF Airconditioning systems
Large Rail System Information Needed
10/07/2010 2:22 PM
I am designing concepts for a rotating platform that will support heavy loads as part of an assembly process. The disc shaped platform will be about 4 meters in diameter, oriented parallel to the ground, and the supported load will be as high as 30,000 kg.
I am considering a circular rail system around the perimeter of the disc to support it and allow low friction rotation. I cannot support the disc near its center. Can anyone suggest suppliers of (circular) rails, rollers, etc. for loads of this scale?
Pathfinder Tags: circular rails
Good Answers: 58
Re: Large Rail System Information Needed
10/07/2010 3:44 PM
As long as you have an axle to keep the disk centered, just put as many standard dolly wheels as you can fit around the edge. Any strong flat surface will support them. Fifteen wheels would only have to support 2000 kg each.
mike k
Good Answers: 29
10/07/2010 3:49 PM
I don't see any railing like I visualize you want but this popped up in a search. Might be an idea in there.
Good Answers: 181
10/07/2010 4:14 PM
I hate to say this but the Victorians did it long before you. I can't see much you can do to alter the railway turntable. Properly centred one man could manually turn a 100 Ton loco.
10/07/2010 4:16 PM
I should have specified that space at the center of disc is occupied - no central axis or support.
Since posting I have discovered the "slewing ring" and I think it will do the trick.
Thanks for your advice.
Good Answers: 123
10/07/2010 10:33 PM
slewing ring ???
Is that a bunch of lawyers? Sorry, my spelling sucks.
If you can bend a steel rod in the round shape required, you could attach steel wheels with a V groove in them. Then the disc would just roll around the fabricated steel ring. Good luck.
Bob
10/09/2010 1:57 PM
Maybe think in terms of a super-sized lazy susan?
Register to Reply 6 comments
abasile60 (1); bob c (1); mike k (1); RDGRNR (1); TonyS (1); Tornado (1)
You might be interested in: Rail Services, Circular Polarizers, Circular Connectors
