Previous in Forum: UPS and Neutral Connection   Next in Forum: 3 Phase 220 V AC in India
Relay CT Ratio
10/08/2010 1:05 AM
We have a MICOM Relay which is used for Feeder protection.
Its CT Rating is 5A.
How to use the above 5A Relay for 1A CT.
Re: Relay CT Ratio
10/08/2010 3:52 AM
Use the password (given by manufacturer) to enter into the relay registers.
Insert the desired changes, press save and exit.
Knowledge sharing is a WIN-WIN situation
Re: Relay CT Ratio
10/08/2010 3:23 PM
Each relay of the MiCOM P14x range is equipped with 1A & 5A software settings...
http://www.areva-td.com/solutions/US_412_US::Solutions::Automation::MiCOM+P14x.html
Good Answers: 244
Re: Relay CT Ratio
10/08/2010 2:00 PM
The AREVA MiCOM Feeder Management Relay (P14x series) has both 1A and 5A current ratings and they have the separate terminals for the connection. See the 'Technical Data Sheet' for MiCOM P141/2/3 (Feeder Management Relays) for detail.
http://areva-td.com/static/content/1139218271939-P14x_EN_TDS_A11.pdf
In Page 8, see "AC Current: Nominal current (In): 1A and 5A dual rated. (1A and 5A inputs use different transformer tap connections, check correct terminals are wired)".
For the wiring diagram, see the pages 32 through 44 for the connection details of 1A and 5A terminals. The 1A input is connected to the terminals C2, C5, C8, C11 and C14, while the 5A input is connected to C1, C4, C7, C10 and C13.
So, you can use either 1A CT or 5A CT with wiring them to the correct terminals.
- MS
Re: Relay CT Ratio
10/12/2010 2:54 AM
Yes i aware of that information,P14x series is having the site selectability configuration.
Problem is how to convert the 5A relay to 1A Relay.
Anonymous Poster (1); mountk2 (2); msamad (1)
