Previous in Forum: Panel Mounted AC or Window AC   Next in Forum: Analysis of Tan Delta and Capacitance Test Result
Synchronising Panel
10/08/2010 5:54 AM
we are executing a 5x500kVA DG set synchronising panel, with five separate dedicated copper plate neutral earthing and we planed to connect the all neutral in the common neutral bus bar, whether this connection is correct or we have to connect the neutral thro neutral contactor. if its incorrect what may be the problems will come?
Re: shajahan
10/08/2010 6:41 AM
I hope you can understand the instruction books for the generator synchronisation panel better than I can understand your post. Otherwise the panel won't be the only thing you'll be executing!
Re: Synchronising Panel
10/08/2010 7:13 AM
How can the thread title change and the contents of posts change? The thread was originally shajahan
I Can Change The Response Title Myself
10/08/2010 12:39 PM
This is being discussed right now. See this thread. A thread title "shajahan" means nothing to anyone but you, so a moderator changed it to "Synchronising Panel" to attract some help for you (spelled incorrectly, but it gets the idea across).
