Previous in Forum: 3 Phase 220 V AC in India   Next in Forum: Synchronising Panel
Panel Mounted AC or Window AC
10/08/2010 3:33 AM
In our Corrugator plant, there are many field panels of different machines having Panel mounted ACs to cool the panels. We have found that the cooling of ACs is not sufficient according to our weather condition. Now I am replacing that Panel Mounted ACs with Windows ACs and control the compressor's operation through a temperature controller. Now someone told to me that Panel mounted ACs are designed so that if water is being condensed, it doesn't through on equipments in panel with blowing air of AC. I am not sure if I have explained well.
Does any body have such experience?
Canada - Member - New Member
Re: Panel Mounted AC or Window AC
10/08/2010 7:46 AM
What you need to be careful with, is that you don't cool your panel below the dew point at your location. Below the dew point condensation will collect on all metal surfaces inside your panel. If you use a window air conditioner make sure it is set to recirculate the air inside the panel. That way you won't be introducing humidity from outside the panel.
The method you use to cool your panel really doesn't matter. The temperature being kept above the dew point, does matter.
Knowledge makes what was impossible, seem easy.
10/09/2010 12:06 AM
Please ensure that condensate tray of the window A.C is connected to the proper drain line. It is installed properly so that accumulated water in the condensate tray will not pass in to the room. Regularly check the filters of the A.C . Do not keep the inside condition of the room too low. Avoid fresh air leakage to avoid condensation on the surface of the panels.
10/09/2010 12:14 AM
Elroy is correct when he states that you run the risk of condensation in the panel. If these are 134a units, the refrigerant fractionates starting about 105f ambient to the point of rapid capacity loss. Much better to subcool the liquid line just before tor cap tube or txv. Common approach would be water cooling with regulating valve. If these are r12 units, the same solution will satisfy. Ideal condensing temperature is about 85f. The panel cooling units lower your rh in the panel and will not cause condensation. This is a common problem because the design engineers have apparently never worked in a plant where the process raises the ambient temp and moisture levels. Sealing your panels better often help because the dryer air inside acts like a sponge and draws more humidity in. This causes more of your capacity to be wasted on latent load as opposed to sensible.
10/09/2010 2:52 AM
pls check Bard A/C unit(see website for more info) - its compact and relieble - we are using it at our District Cooling Plant from UAE, Qatar, Kuwait, Oman and other GCC country with no complaint so far.
Register to Reply 4 comments
Anonymous Poster (1); CONWAYMECH (1); Elroy (1); mrswamy (1)
You might be interested in: AC Motor Drives, DC to AC Converter Chips, AC Motors
