Previous in Forum: Grounding a 3 Phase 480V Transformer   Next in Forum: Droop CT
Motor Issue
10/10/2010 5:14 AM
Hi
I have a 60hp motor operated with a star delta starter when the starter is moving from star to delta the motor is getting stalled with spark in star contactor, and the starter is in on state but the motor is stalled
please could you help me to solve this problem
Good Answers: 181
Re: Motor Issue
10/10/2010 5:44 AM
Does the delta contactor close?
Or does the supply trip?
India - Member - New Member
Good Answers: 164
Re: Motor Issue
10/10/2010 7:05 AM
As the motor is able to start in Star, there is no possibility that it is stalling due to mechanical overload in delta (the torque in delta is 3 times that in star).
You say there is a spark in the Υ contactor, but is it very severe? It may have welded, thereby preventing changeover to delta ?
Is there short-circuiting of the incoming supply when it changes from Υ to Δ ? This is quite common if there is no 'transition delay' of at least 30 ms between Υ contactor dropping and Δ switching on.
Good Answers: 117
Re: Motor Issue
10/10/2010 12:30 PM
sounds like you have your connections the wrong way around, check those first then the SD starter checking the contacts, also the time taken for the change over, is it manual or automatic?
brich (1); kvsridhar (1); TonyS (1)
