Previous in Forum: How Can I Obtain the Required Thyristor Triggering Pulse Timing Sequense for Syn   Next in Forum: help !!!
8 comments
Three phase induction generator on a single phase supply
10/11/2010 3:11 PM
Hi,
I'm really stuck on a problem for my final year project in my taught Masters degree and any suggestions what might be going wrong would be greatly appreciated.
I'm trying to run a three phase delta connected induction generator on a single phase supply using a Steinmetz connection. The Steinmetz connection is a single capacitor connected across phase B or C depending on which direction the machine is running with phase A connected to the single phase supply. I've been using the book Distributed Generation by Chan and Lai to get the formulas shown below. It says in the book for a balanced machine the following applies.
Yp = 1/Zp =|Yp|∠-ϕp
Where Yp is the positive sequence admittance of the generator and ϕp is the positive sequence impedance angle.
B1 = 2Yp sin⁡(2π/3 – ϕp)
B2 = 2Yp sin⁡(ϕp - π/3)
B = 1/Xc
C1 = B1/(2.π.f)
C2 = B2/(2.π.f)
I ran the machine as an induction motor first and a certain calculated speed it had an impedance of Z = 124.26∠60 (62.2 + j107.6) and this gave a value of Yp as 0.0085∠-60, B1 = 0 and B2 = -0.0139388. A modular value of B2 was used to calculate a positive capacitance value and this was calculated as 0.00004439 which is equivalent to 44μF. This capacitance was placed on the motor across phase B and it worked really well. It was able to run with a load and all the phases were in balance with the voltages and currents very close together. (The figures have been rounded up for these examples as I have been using an excel sheet that has much longer values in each cell)
I tried to run the machine as an induction generator and a certain calculated speed it had an impedance of Z = 104.41∠120 (-52.26 + j90.4)(the real value is negative as it has a negative slip) and this gave a value of Yp as 0.00958∠-120, B1 = -0.016588 and B2 =0. A modular value of B1 was used to calculate a positive capacitance value and this was calculated as 0.00005282 which is equivalent to 52μF. This capacitance was placed on the machine across phase B and it wouldn't work properly. There was a lot of imbalance in the currents and voltages.
Would anyone have any idea of why it is not working for the induction generator the same as for the induction motor as all the literature I have read has said that an induction generator behaves exactly the same as an induction motor but it is just run faster? I have been doing tests by trial and error but I have to give a reason why it is not working. If any more information is required, just post a question and I will answer it.
Thanks
Declan
Re: Three phase induction generator on a single phase supply
10/11/2010 3:22 PM
dec335; what sort of power source to drive the generator, gas engine, or electric motor? to dive it overspeed. perry
10/11/2010 3:32 PM
Perry,
I'm using a DC motor in the lab to drive it overspeed but eventually if the project works, it will be installed in a small hydro project.
Declan
10/13/2010 3:38 AM
Hang on. It started being driven from a single phase supply, now it's driven by a DC motor. Can the confusion go away, please?
10/13/2010 9:42 AM
I am trying to use a three phase induction machine to generate electricity that is connected to a single phase supply. I am currently doing work in the lab to get the setup running smoothly and then the machine will be installed in a small hydro project where three phase power in unavailable. I am using the DC machine in the lab to run the induction machine over synchronous speed so that it operates as a generator. I have also done testing in the lab with the induction machine running as a motor, driving a load and everything worked as expected as shown in my post above but it is not working well when it is running as a generator.
10/14/2010 2:45 AM
How do you expect a water wheel in a small hydro to run above synchronous speed? And how do you expect someone to offer job with a Masters but doesn't know if a synchronous generator is more efficient or an induction.
10/12/2010 12:40 AM
In simple terms, you do not have the ability to draw a CIRCLE DIAGRAM for the equipment otherwise this topic would not have been here in discussion (sorry to have said that).
While you are trying to support your thesis with impedance relationships without realizing that a machine has a working principle on which it works.
With single phase in conjunction with capacitor at motor terminals produces a phase shift to give rotating magnetic field across the rotor symmetrical to a three phase connection to the three phase motor windings.
When turned around as a generator the three phase motor windings have the inherent ability to produce the balanced desired results - effect of the capacitor across two of the terminals in this particular case is to cause considerable distortion of the output.
Knowledge sharing is a WIN-WIN situation
10/12/2010 6:17 AM
mountk2,
The generator does not have the ability to produce the balanced desired results as I have tried to run it without a capacitor across the phases and there is a massive imbalance in the phases which causes overheating.
Declan
10/12/2010 9:35 AM
I have to say that induction generator alone is incapable to supply a power system and therefore MUST ALWAYS operate in parallel with either synchronous machines or with a set of balanced capacitors.
As of reasoning it should be noted that the generator draws down all its excitation from the system and so must receive a definite amount of lagging kVA for a given voltage and load currents.
(For an induction generator the power factor of the output is fixed in value by the generator characterstics and is always LEADING, standing indipendent of the external circuit).
Register to Reply 8 comments
Anonymous Poster (1); dec335 (3); mountk2 (2); perry (1); PWSlack (1)
