Previous in Forum: Changing Oxygen Sensors   Next in Forum: 98 Trans AM Oil Problem
16 comments
MAZDA RX-8 2005 Codes
10/11/2010 5:24 PM
Hello guys!!
my mazda RX-8 2005, the check engine light came on yesterday, a mechanic put the scanner on it and says that P0456 and P0661 problems, anybody can help me to tell me how to fix it and what those codes mean??? please!!!
Dave
Puerto Rico!!!
Re: MAZDA RX-8 2005 codes??
10/11/2010 5:44 PM
10/12/2010 5:58 PM
how do I fix it???
what I should do ti fix the problem??
10/12/2010 11:36 PM
Ah come on! Did you read any of the leaks provided for you? Hint: start by changing one fairly inexpensive, really easy to change part, ,, it screws in by hand...
Good Answers: 60
Re: MAZDA RX-8 2005 Codes
10/13/2010 5:42 AM
URL of this page: http://www.obd-codes.com/trouble_codes/
OBD-II (Check Engine Light) Trouble Codes
Resources:
Toyota Prius Forum
Toyota Venza - Ford Flex
Welcome to OBD-Codes.com, your headquarters for everything OBD-II related.
For more information on what OBD codes are, OBD-II codes explained, or answers to other questions, visit our FAQ area.
See also - Check-Engine-Light.com & Engine-Light-Help.com
CR4 Admin: Modified Post
Copyright Violation: Reduced copied text according to copyright law. Please see Section 13 of the CR4 FAQ about posting copyrighted material.
Good Answers: 60
10/13/2010 5:52 AM
Good Answers: 60
10/13/2010 9:13 AM
Both the codes are power train codes as denoted by the P
the other person who posted with the error codes is wrong.
please look at link below and see if you can find the Vehicle Specific Code
http://www.google.co.uk/search?q=mazda+P0661&sourceid=ie7&rls=com.microsoft:en-gb:IE-SearchBox&ie=&oe=&rlz=1I7GGLT_en&redir_esc=&ei=-rC1TIu7E42L4Qb9toGhDQ
10/13/2010 11:53 AM
"the other person who posted with the error codes is wrong."
What do you mean I am wrong? I posted
"How does the mechanic get paid if you fix these yourself?" in lieu of a link is a valid question, intended to prompt our poster into confessing he has gotten the trouble codes at no charge, and is looking for more free advice. If he had paid the mechanic for the diagnostic, he would have gotten information on what the codes indicate.
Good Answers: 60
10/13/2010 12:03 PM
Aha i have made a mistake sorry i thought the line P0456 was an air con fault, but reading it correctly its the Vapour reclamation unit that stops the fuel vapours entering the atmosphere
Sorry please if poss delete my comment Sooooory
10/14/2010 8:36 AM
jajjaj thank you Peter!!!, that may cause to th car to shut off while running???
Good Answers: 60
10/14/2010 9:43 AM
its a possibility as there would be too much air being sucked in along with the fuel.
try this link
http://www.memoscan.cn/en/DTC_lookup.asp
taken from above link
Mazda Code Retrieval Accessing Trouble Codes 96 & later are OBD2 systems
Carbureted Models
System malfunctions detected and stored in the emission control unit can be displayed using the self-diagnosis checker tool No. 40-H018-9A1. Any current or memorized malfunctions are indicated by a displayed code number and a corresponding buzzer. A monitor lamp on the checker indicates oxygen sensor operation. A normal air/fuel ratio is indicated by a continuous flashing of the lamp. The lamp will not light continuously if the air/fuel is lean and will not light at all if the mixture is rich. Refer to the manufacturers instructions for operating procedures of the self-checker tool.
Fuel Injected Models
A system selector tool No. 49-B019-9AO or equivalent on OBD systems and tool No. 49-T088-OAO or equivalent on OBD II systems, can be used to diagnose the main input or output devices. Systems are displayed as code numbers appearing on the system checker. Refer to the manufacturers instructions for operating procedures.
Clearing Trouble Codes
Carbureted Models
Disconnect battery ground cable for a minimum of 10 seconds to clear trouble code stored in the memory.
Fuel Injected Models With OBD
Disconnect battery ground cable for a minimum of 10 seconds, then depress brake pedal five times to clear trouble code's stored in the memory.
Fuel Injected Models With OBD II
Connect SST (NGS) tool to data link connector 2. Then select "Clear Diagnosis Codes" function and erase diagnostic trouble codes from the NGS memory.
Your mechanic with the scanner is not very good is he/she ?
Good Answers: 60
10/14/2010 10:05 AM
ALL POSSIBLE DIAGNOSTIC SOCKET LOACATIONS
P CODES TAKE FROM ABOVE SITE
C CODES
10/14/2010 10:37 AM
Thank you Peter°!!
question that may cause that the engine shut off while running the car??? its feel like the car has no Gas!!!! last week that happend, then I wait for 10 minutes and the car start and running without a problem!!!
thank you budy!!!!
and thank for help my with my Jaguar Problem!!!
Dave
Puerto Rico!!!
Good Answers: 60
10/14/2010 10:52 AM
Its Like Being A remote Control Mechanic.
Just a thought,,, when the car cuts out like its run out of gas, Go to filler where you put gas in and listen as you remove fuel cap is there an inruse of air ( a hissing sound) if yes the one way valve on the filler is blocked
the tank is supposed to have a slight vacume to stop fumes escaping, but if vacume goes to high ( or low if you see what i mean) then the fuel pump will not be able to send fuel to injectors or carb.
and in extreme cases can crush the fuel tank.
easy to check run car till it stops remove fuel cap as you listen for inrush of air
Glad to be of help
Good Answers: 60
10/14/2010 5:00 PM
I WONT BE ABLE TO HELP YOU ANYMORE ALL MY POSTS ARE BEING MONITORED BY THE OWNERS OF THE SITE.
SO NUTS TO THEM
Register to Reply 16 comments
baxterm (1); dervech (3); Doorman (2); peterg7lyq (10)
