Previous in Forum: Flange Bolt Torques   Next in Forum: Fluid Power Design Problem - Working with Steel Tube
Wankel Engine Dimensions
10/14/2010 12:45 PM
Hi,
I'm Final Year mechanical Engg. Student n wanna make some project my probable choice is wankel engine but i have no idea about it's design n dimensions can any body help me put in this regard or you can suggest some other project based on kinematics of machine.
Thanks
Go Against The Flow
Re: Wankel Engine Dimensions
10/14/2010 1:46 PM
Well, let's see.
First your heat pump project, now this rotary engine.
Combine them. Investigate 'Rotary Stirling Engine' and 'Quasiturbine'.
The more I think about it, this may be too good of a suggestion to give you. Better take it before I remove it! Good luck.
10/15/2010 4:55 AM
the idea u gave is quite good i went through both 'Rotary Stirling Engine' and 'Quasiturbine' but in case of rotory engine i'm struggling with designing and these two are far more complicated than it but i can consider "stirling Engine" . from where can i get the CAD projection of stirling engine having dimensions Thanks
Go Against The Flow
10/14/2010 2:37 PM
I think you should
Do you understand this????
The wankel engine with moving rotor at backplate. Video
Please report back to us what you think this is.
I think this project is far, far over your level of comprehension or intelligence.
Good luck.
10/15/2010 4:11 AM
yes of course i understand this,For ma project i'hv studied a lot about wankel engine -it's working,drawbacks etc. the issue i'm facing is designing of it's rotor housing and placement of spark plugs etc. imean i have no idea about it's designing Thanks for ur support. I think these 2 videos best explain it's wrkng http://www.youtube.com/watch?v=6BCgl2uumlI http://www.youtube.com/watch?v=lyItjvs8nvI&feature=related
Go Against The Flow
10/15/2010 5:05 AM
dashing deep (2); Doorman (1); lyn (1); woodygb (1)
