Previous in Forum: Wankel Engine Dimensions   Next in Forum: Centrifugal Pump Selection
Fluid Power Design Problem - Working with Steel Tube
10/14/2010 3:47 PM
I have been placed on a project working with large amounts of steel tube that will be placed in areas not easily accessible for maintenance once the installation is complete. I'd like to join these tube assemblies by brazing the individual components together, instead of flaring, o-rings, or other mechanical means. I have yet to find a product that will allow for the spreading of hydraulic tube to preform these operations, or a "coupling" type fitting. Anything I have found thus far allows for the conversion of tube to another style for connection purpose (JIC, or ORFS). Any thoughts or input?
Chris
Pathfinder Tags: brazing coupling Hydraulic tube
Good Answers: 58
Re: Fluid Power Design Problem - Working with Steel Tube
10/14/2010 4:17 PM
You don't mention what the wall thickness is of the tube you plan to use but what about something like this: http://www.harborfreight.com/large-tail-pipe-expander-37354.html
There are other types and sizes available.
Use Google and search "exhaust pipe expander tool"
Or
If it is steel tube similar to RGS (Rigid Galvanized Steel) conduit what about threading the tube, installing a coupling and then brazing?
10/14/2010 5:26 PM
Another term: Swaging.
10/14/2010 7:27 PM
I've looked for swaging tools for the brazing of hydraulic tube (wall thickness in the .065 range, with an OD of 0.5") but so far everything I have found involves the swaging of a crimp ring or ferrule onto the tube, not the expansion of the tube for insertion of "next section".
Chris
Chris
10/14/2010 8:09 PM
You are probably looking for flaring tools.
"You can't get the wood you know."
10/14/2010 11:29 PM
I have been in the Hydraulic busines for 30 years. Worked on old machines from the 40's up to the newest stuff. The only "brazed" fittings I have come across were for use with face o'ring type tube ends. These were silver brazed.
As for swaging a good hydraulic hose shop may have hose crimping machines suitable to swage your tube..... but it just isn't done. Flare for upto given wall thicknes, and external crimp type fittings (Parker BU works for me) for heavy wall tube.
Bin there, done that, then done that again and again and now I forgot where I was.Is this what it means to get old?
10/15/2010 8:08 AM
If it is stainless steel, why not use a Swagelok or Parker coupling? These will probably last as long as the tube. Alternatively the tobes can be butt-welded using orbital welding.
If it is something like copper, then (thinking out loud) you might try getting some larger size tubing with inside diameter matchibg your tubes outside diameter and cut off suitable lengths to make "brazing" couplings.
Register to Reply 6 comments
Anonymous Poster (1); Cbrunner (1); Henry Crun (1); KJK/USA (1); MIKE L. (1); Tornado (1)
