Previous in Forum: Bearing Capacity and Soil Type   Next in Forum: How is Glazed Drainage Pipe Cut?
Stucco on a Cracked Concrete Wall
10/14/2010 12:55 PM
I have a 12" thick reinforced concrete retaining wall which has been stuccoed. The stucco is now cracked in places, generally following the control joints, but not following the joints in other places. Some of the cracks are 1/4" wide.
Can I remove all the stucco along the wall, grind out all of the irregular cracks, apply some sort of elastic material in the groove, and then stucco over that material with elastomeric stucco?
Over the ten years or so, water has gotten behind the stucco from the open cracks in the top of the wall, now causing the stucco to loose its adhesion to the wall. Freeze/thaw is always a problem in our area since we are at 7000 ft. elevation.
Good Answers: 179
Re: Stucco on a Cracked Concrete Wall
10/15/2010 10:17 AM
Yes, you can remove the existing stucco and install a preformed elastomeric joint material, at least 1/4" or 3/8" i width. Make sure the vertical joint locations are no greater than 12 feet on center and line up with any expansion joints present in the concrete wall. Hopefully those existing wall joints exist! You didn't say. If they don't exist then I recommend that you saw-cut new crack control joints into the existing 12" thick concrete wall....make sure that they're at least D/6 in depth (in your case this would be 2.0 inches, but don't cut through any underlaying rebar!). Thoughly clean-out sall dust and debris from the cracks with high pressure compressed air before applying the new joint filler material. Fill-in these crack control joints with a good quality exterior grade silicon caulk that has superior thermal expansion properties.
I would not recommend covering the newly installed elastomeric joint material because any thermal expansion and contraction of the stucco material (and concrete wall underneath) will cause reflective cracking in the stucco overlay at the new joints and other thermal cracking between the vertical joints.
Make sure you use a good quality latex-based concrete binding agent on the newly roughened concrete surface before applying the new stucco.
