Previous in Forum: angles   Next in Forum: 4W+G Generator and Utility with Multiple 3p transfer switches
Engineering Fields - Control Engineering - Newby Member Long Time User Engineering Fields - Instrumentation Engineering - New Member
Safety Relay Schematic
10/14/2010 3:32 PM
I'm looking for a published explanation of a Safety Relay Schematic.
I've found many examples of how to use the relays, but no explanations of what the various connections (S33, S34, S10, S11, S31, S32, as a short list of many connections) do.
I'd rather not have to reverse engineer the functionality and miss something. Does anyone have a link to a good resource on explanation of Safety Relay Schematic?
Thanks for the help.
Re: Safety Relay Schematic
10/14/2010 3:58 PM
Yo, take a look here
http://www.schmersal.net/cat?lang=en&produkt=yyw733331kfv3pci8h5694603z9rnm
There is all you need
TTYL ,ciao T L ;)
Humans use 10% of their mind , WE take the rest
10/14/2010 4:22 PM
This is a good start. It's beginning to fill in the holes.
Thanks.
06/21/2012 4:04 PM
Hello,
I teach wind turbine electrical concepts at a community college. In the wind industry, we use safety relays extensively in fail-safe, emergency stop systems.
I'm not sure if you're still looking for info on safety relays, but I recommend going on line and searching for Allen Bradley's safety relay pdf (catalog # 700-Z). The first seven pages of it explain the concept of safety relays better than any other source I've seen.
If you email me at gsmeeuwsen@gmail.com, I will be glad to send the pdf to you too.
Good luck.
-Greg M.
Register to Reply 3 comments
BDThompson (1); gmeeuwsen (1); timelord (1)
