Previous in Forum: Actual Load Calculation   Next in Forum: AC and DC Currents
Why 400Hz Used For Brushless Excitation System
10/15/2010 2:41 PM
hello friends in a brushless excitation system, for giving excitation supply to rotor, we are using 16 pole, 3000 rpm, thus induced voltage = 220V, 400Hz, my doubt is why particularity 400Hz chosed
i want clear view abt
1. why 400Hz used for Brushless excitation system, insist of 50Hz?
2. If DC rectification efficiency increases with increased AC frequency input ?
Pathfinder Tags: Brushless excitation system
Good Answers: 244
Re: Why 400Hz used for Brushless excitation system
10/15/2010 9:29 PM
In the brushless excitation system, the excitation generator's (called exciter) field is stationary and armature is rotating. The AC is produced in the excitation generator's armature and it is then converted to DC (for the field supply of the main generator) using the rectifiers which are fixed to the rotating shaft. With the use of high frequency of the exciter output, the frequency of the ripple of DC is also high, which helps effective filtering of the ripple with the high inductive nature of the field coil of the main generator with the use of filtering capacitors across the rectifiers. Thus, the good quality of DC is produced and passes through the field for the excitation of the main generator.
So, the use of high frequency of exciter output voltage is used to create the good quality of DC for the main generator's excitation.
-MS
You might be interested in: Brushless Motors, Gearmotors , DC Motors
