Previous in Forum: Coconut Sugar Manufacturers   Next in Forum: Request for the Technical Papers
8 comments
How to Identifty Hydrogen Induce Crack Treatment Pipe
10/15/2010 11:48 PM
Hello everybody,
From physical stock is anybody guide me how to identify HIC treated pipe & fitting.
RAHUL PATEL
Re: How to Identifty Hydrogen Induce Crack Treatment Pipe
10/17/2010 2:14 AM
What kind of a plant, what atmosphere, temperature and pressure.
You may be able to eliminate the possibility before you start.
10/17/2010 12:14 PM
russ123
THANK YOU VERY MUCH FOR YOUR RESPONSE!!!...
Actually all design engineering calculation completed.
The guy who store the material previously mix up all material together.
Now all this come on my head & i have segregate & issue material for fabrication.
I don't know how to identify HIC material from this lot, can you help me in this matter.
This are the spec. we are using : API 5L (normal & HIC treated), A106 & A333
RAHUL PATEL
10/17/2010 12:17 PM
You mean this material is used - has been in hydrogen service?
10/17/2010 12:30 PM
Material going to use for sour gas line - Hydrogen sulfide (H2S)
RAHUL PATEL
Good Answers: 243
10/18/2010 11:10 PM
Abdel Halim Galala or QAQCpipeman should be able to help you with this one.
I think (I'm a Bar metallurgist) that to eliminate the possibility of HIC, the material would have been thermally treated, so a difference in appearance where one shows evidence of a high temperature treatment vs one that does not.
However, this is speculation as I do not have the API std in front of me.
Look for evidence of processs differences, based on the spec.
Milo
10/19/2010 12:44 AM
I have no direct experience with sour gas pipelines. At Essar the steel mill section produced qualities of coil designed for sour gas - a good money maker.
To the best of my knowledge, the chemistry is different. We had no heat treating facilities. Seems those grades were referred to as X__ grades.
Is this old material being reused or new material that was mixed up?
Why do you think there may be hydrogen induced cracking present?
Good Answers: 243
10/19/2010 9:49 AM
Russ, They have designed and know that they need two different materials, one protected for Hydrogen, the other not.
Now they are going to build, and they find that their supplier has mixed lots/ lost identity, and they are trying to figure out how to solve that problem.
Milo
10/20/2010 6:06 AM
Mr. Milo & Mr. Russ
Thank you very much for your reply.
Mr. Milo is clear on this point.
Actually we are constructing refinery in KSA for this different type of material we have use & some material already store in our yard.
Now I have to segerate HIC material & Non HIC treated material, morethan 5000 pipes stored in our yard & from this lot I don't know how to identify (physically) HIC material and for this I need help.
RAHUL PATEL
Register to Reply 8 comments
Milo (2); RAHUL PATEL (3); russ123 (3)
