I plan to install an induction motor as a grid connected asynchronous generator driven by a water turbine. The available torque will vary greatly (10 to 50KW) due to seasonal river levels.
I am considering installing a 55KW motor to ensure that it is never driven past its nominal working torque/current to avoid overheating.
For a squirrel cage motor/generator current and torque appear to be more or less linear up to 100% load, does this mean that running at half load or less (0.5% slip) will be equally as efficient and have a better pf?
If this is the case should I consider a larger motor/ generator?
