An exact lifetime can't be given, as the conditions of every situation are different. Testing the dielectric strength & contamination on a periodic time scale will give you an indication as to the action required.
Your local supplier of the oil will probably have on site filtration equipment, much cheaper than replacement. With replacement the oil will be sent for recycling, so at some time in the future you'll be buying your own oil back.
mostly we heat up the transformer's oil for increasing dielectrical strength? is that method is valid and if yes then what are the limitations of temperature and dielectric strength????
If your BOSS says nothing is impossible.... Ask him: try to wear a condom just after sex.
