Previous in Forum: Changing Star Delta Motor Direction   Next in Forum: Protective Relay
Transformer
10/17/2010 12:34 PM
i have 33kv/862v 3 phase transformer. if i give only one phase at primary side then what will be actual voltage at secondary side? if i m giving only r ph supply at primary then what will be secondary volatge in each phase ?
Re: Transformer
10/19/2010 4:18 AM
Is there a neutral on the primary side? If there isn't, and only one phase is connected, the secondary voltage will be 0V.
Re: Transformer
03/05/2011 6:29 AM
There is no neutral on primary side. 3 ph. delta/star transformer. in secondary star neutral is not coming out of trafo, only 3 ph coming out in secondary of trafo.
Register to Reply 2 comments
