Previous in Forum: Testing Isolation Resistances and Dielectric Withstand on Wires   Next in Forum: Fire Protection for Transformers
Audio Hi-Pass / Low-Pass Filter
03/14/2007 9:32 PM
Can one of you electronics guru's send me a circuit or to a link so that I can build an in-expensive hi-low audio cross-over ?
I want to plug into either the "line out" jack or "spkr out" jack of my computer's sound card ( good for about 1 watt ) and enter into this cross over at the "line level" then Bi-Amp it into the "big boy" amplifiers.
I don't need sophistication, but I think I'd like it better than just an RLC filter.
By-the-way, I do have the cross-over out of a blown sub-woofer ( has both channels ). It has (2) hefty choke coils and (4) 125uf capacitors. But I was thinking that the line level might not produce enough audio current ( driving the input of a power amp), to allow the chokes to function.
Regardless, if someone has a circuit with readily available components I can mount on a breadboard, I'd really like that
Unless you're the lead dog on the sled, the view is always the same....
Re: Audio Hi-Pass / Low-Pass Filter
03/16/2007 12:48 AM
It's old, but check out 'Audio IC OP-AMP Applications', by Walter G Jung, Howard W. Sams, publisher. The edition I have was printed in 1976.
03/16/2007 5:15 AM
I use this all the time
http://www.lalena.com/Audio/Calculator/XOver/
If it's a simple crossover stick with 1st order designs.
03/16/2007 5:20 AM
I think you're going to have to use LRC.
Chokes should still work at low power.
03/19/2007 11:24 PM
I really like the looks of the circuit from the westhost.com link.
It's exactly what I want and hopefully I can build it on a small project board.
I'll let you know if it's a success or failure....thanks all !
Register to Reply 4 comments
Anonymous Poster (2); dkwarner (1); Sniccus (1)
