Previous in Forum: Flange Design 42" Class 1500 #   Next in Forum: CAD/CAM Software - Industry Standard Tool
Engineering Fields - Piping Design Engineering - New Member
Plate Material for Flanges
10/19/2010 4:14 AM
Why don't we use plate material (like IS 2062) for making flanges? Why only forged one like A 105. I went through posts where bit of differentiation was there between IS 2062 & A 105 but didn't make to the reply. Both materials are having same yield strength and tensile strength. Then where lies the difference between application?? Thanx in adv.
annu
Re: Plate material for flanges
10/19/2010 4:45 AM
CR4 Admin: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Re: Plate Material for Flanges
10/20/2010 2:52 AM
Forged flanges do have better grain structure than machined flanges out of plate...
10/20/2010 3:05 AM
Plate Materials are used to fabricate materials having even geometry ( eg Spectacle Plate from A 36) . Since the Flanges are basically prepared by forging process hence the have been designated for use by Forging Grade Materials like A 105 , A 182 F 316.
Good Answers: 38
10/20/2010 12:55 PM
Anoop...
Follow the code of record for the piping system.
Specifically, what is the code of record ?
What is the design temperatures and pressures of the system ?
You cannot use any material you like for a system. Both ASME and PED power/process piping codes contain restrictions on the usage and application of materials for flanges.
Tell us more....
10/20/2010 1:46 PM
Depends on the usage. I have had many flanges made of 2062 (A36) plate when I worked there.
If pressure and temp do not pose a problem then it is a function of economics. Making a flange is time consuming when you only do a few.
MJCronin (1); Naved gcc (1); russ123 (1); woyaodixingfu (1); yesyen (1)
