Previous in Forum: Mission Critical Facility Engineering & Management??   Next in Forum: reverse power shutdown alarm
Sf-6 Gas Loss
10/20/2010 11:48 AM
1 psig of SF-6 gas lost over a 30 minute period equals how many actual SF-6 pounds?
Re: Sf-6 Gas Loss
10/20/2010 7:08 PM
Is this an electrical question?
Re: Sf-6 Gas Loss
10/21/2010 1:49 AM
It is crucial to make up the gas loss, take into account the weight from the cylinders when you have made up for the psig loss.
Knowledge sharing is a WIN-WIN situation
Good Answers: 131
Re: Sf-6 Gas Loss
10/21/2010 9:12 AM
It depends on how much lbs of SF6 was in the apparatus to start with. The nameplate may tell you that. Consult the manufacturer.
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
Re: Sf-6 Gas Loss
10/21/2010 10:46 AM
Yeah. Damn right it does, too. It also depends on the temperature. Giz another blanket, Guvnor? It's bleedin' freezin' today! <Sneeze, dribble, splutter, cough>
Essex jobs for Essex yobs! <Burp>.
Re: Sf-6 Gas Loss
10/27/2010 2:29 PM
If your SF6 insulated switchgear is leaking that much I would suggest replacing it.
As others have said it depends on the tank size (amount of SF6 gas) and original tank pressure (there is no direct correlation between psi drop only and pounds of gas lost).
jack of all trades (1); mountk2 (1); PeterT (1); Stinky Pete (1); wareagle (1)
