Previous in Forum: Gasket   Next in Forum: Valve Handleheel Orientation
Flat Closure
10/22/2010 10:58 AM
When to install flat closures?
What are the major differences between butt-welding cap and flat closure?
Good Answers: 61
Re: Flat Closure
10/22/2010 11:41 AM
A proper butt weld Pipe Cap of the same schedule is designed to hold under the same internal Pressure and Temperature conditions as the pipe of a specific Schedule. No additional calculations are required.
A flat Plate used for an end closer will need to be calculated to insure that the thickness will hold up to the internal pressure/Temperature of the pipe system. Then you need to have a special weld that will also hold.
Use the Weld Cap, it is cheaper in the long run.
Do it once and do it right
Re: Flat Closure
10/22/2010 11:50 AM
Hello Guest. I am curious...
Will you be allowed to bring PennPiper to your next exam? He has answered three of your homework questions; will he get extra credit for doing so?
You might be interested in: Flat Belt Pulleys, Flat Panel Displays, Flat Springs
