Previous in Forum: Continuous Operation of Fire-Booster Pump   Next in Forum: SS Fasteners and Galling !!
Grade of Aluminium
10/23/2010 11:56 AM
Dear friends,
can u suggest the grade of aluminium which i can machine , tap small holes like M2, and M3 and get it good anodised.
Re: Grade of Aluminium
10/23/2010 9:10 PM
Just about any Al can be drilled and tapped and anodized.
2024 and 6061 are both commonly available.
Need more info.
10/24/2010 1:51 AM
Thanks! is quality of anodising depends on its grade
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
10/25/2010 6:11 PM
If there is a difference in anodizing quality, between the two alloys of aluminum that lyn mentioned, it shouldn't be anything that you will be able to actually see. 2024 is a bit stronger for structural uses, but if you are talking about small holes, that won't really matter. 6061 might be a bit less expensive.
Regarding anodizing... what you should be more concerned about is any welding that you may need done. Unless you choose your aluminum welding rod properly, you will definately see a difference in anodizing quality between your base metal and your weld.
Register to Reply 3 comments
lyn (1); Madhukar Saran (1); Out of Box Experience (1)
You might be interested in: Pycnometers, Filler Alloys and Consumables, Gage Blocks
