Previous in Forum: Tractor PTO Power   Next in Forum: D-4 Engine Problems
1988 Ford Ranger
10/24/2010 8:31 PM
I changed all plugs and wires.Made sure to put wires on right place have diagram ,motor turns over but will not start
Re: 1988 Ford Ranger
10/25/2010 3:25 PM
Did the truck start and run before you "...changed all plugs and wires.Made sure to put wires on right place have diagram"?
Is there fuel in the tank?
11/11/2010 7:09 PM
if not check to see if you have a good spark and if not check your gound wire some ford had a y in the wire that would go bad it would go the ENG AND FRAME hope this work for you
10/25/2010 4:04 PM
Talk about the proverbial dumb question;
Is the diagram you are using, the correct one for the year ,and engine model of your vehicle?
Did you replace the wires one at a time to insure they are going in the right direction on the cap? Let us know if that is a possible problem and maybe we can get you the correct direction, among other things.
h
Good Answers: 58
10/25/2010 6:30 PM
Is this a four or six cylinder motor? Does it have a distributor? The first thing to check on distributor models is to check for spark at the center terminal. If it does not have a distributor, track back from the coil pack to find power. On my '90 a connection about two feet from the coil pack had broken down. A little cleaning had me going again.
mike k
Good Answers: 179
10/26/2010 8:22 AM
Hey for Pete's Sake, it's a blasted Ford ......."FIX OR REPAIR DAILY"!!!!
10/26/2010 10:34 AM
Actually not.
The thing ran fine until he fixed it. Don't fix or repair daily (DFORD) works in this case.
BTW, Ford announced yesterday quarterly earnings of $1.6 billion. Not sure Toy or Obama Motors can make such claims!
Anonymous Poster (2); bigroger (1); CaptMoosie (1); Doorman (1); mike k (1)
You might be interested in: Power Plugs, Plugs, Stoppers and Inserts, Bus Plugs
