Previous in Forum: Tolerance of Ovality in a Mill Pipe   Next in Forum: Inspection Lab Temperature Requirements
gasket
10/26/2010 4:30 AM
can grease be applied on the groove of a carbon steel ring type joint flange for installing rtj gasket?
Greasing a gasket ??
10/26/2010 4:54 AM
You posted this in QA-QC Quality - Assurance Quality - Control . You answered it yourself. ONLY according to approved Manufacturer's Specifications and released for Construction T L.
Humans use 10% of their mind , WE take the rest
Re: gasket
10/26/2010 8:44 AM
I have used a very small ammount of silicone grease to hold the gasket in place whilst i position things so I would say yes, except if the grease would prove detrimental to the substance in the pipe. Hope this helps
Torque is not cheap
Re: gasket
10/26/2010 8:50 AM
Didn't like the answer you got here?
mansoormech Participant
Gaskets 10/24/2010 10:56 AM
Can grease be used for carbon steel rtj gasket installation and if yes which standard tells about it and if no which standard tells about it?
Re: gasket
10/26/2010 9:56 AM
Of course he/she didn't like your answer. You acted like a good mentor or parent. Obviously he/she didn't know what to do when asked to work.
Re: gasket
10/26/2010 11:56 AM
If it's an oxygen line (and possibly some other fluids), no oils are greases are allowed. In most other cases, anti-seize or a lubricant compatible with the piped fluid can be used, and is often recommended.
Re: gasket
10/26/2010 12:16 PM
A carbon steel ring is unacceptable for an Ultra High Vacuum chamber flange with any kind of outgassing grease. You should have learned that in vacuum 101.
lyn (1); merc600sec (1); redfred (2); timelord (1); Tornado (1)
