Previous in Forum: Supply For Spring Charging Motor   Next in Forum: What is Sandwich Busduct?
Star Delta Starter - 415v
10/29/2010 7:55 AM
If the voltage is 415, What is the range of capacity of motors for which star delta starter is used? How is the timer set for changing from star to delta (in how many seconds) ?
Good Answers: 181
Re: Star Delta Starter - 415v
10/29/2010 7:59 AM
Search star delta starter.
Good Answers: 29
10/29/2010 10:53 AM
Your post is a little too vague (devoid of specifics) to elaborate on such a wide field. Here's some Wiki info you can read and then hopefully rephrase with some detail.
10/29/2010 11:21 AM
Thats great star delta delta star but be careful of wiki.
10/29/2010 11:43 AM
In some countries with weak power systems DOL starting was limited to 5HP. For above 5hp to about 30hp they used star-delta starters. Above 30hp they used slip ring type starters. In countries with strong grids there was no limit of 5hp for DOL.In star-delta starters during changeover from star to delta a current surge which is more severe than DOL may occur. So they developed the closed transition type star-delta starter. The limit depends on the load characteristics as the starting load in star-delta starting is low compared to DOL. They have other types too like auto transformer,VSD, VFD,soft start etc depending on the application.Changeover time fro star to delta too depends on load characteristics but normally 5secs is acceptable.
pnaban
11/01/2010 5:58 AM
It depends upon the capacity of the upstream supply and whether or not a Peak Demand Tariff is being charged.
Anonymous Poster (1); pnaban (1); PWSlack (1); RDGRNR (1); TonyS (1)
You might be interested in: Counter and Timer Boards, Power Transformers
