Previous in Forum: True and Duplicate Honey   Next in Forum: Do Doctors Use CR4
RTP 399 X 102168 A PC
10/30/2010 8:53 AM
I need to know the initial moisture contenet and final moisture content of PC (Polycarbonate) RTP 399 X 102168 A material.
If possible also want to have the complete data cheet of the same material.
Sandip Shah
Re: RTP 399 X 102168 A PC
10/30/2010 10:19 AM
The manufacturer can supply the data sheet, if you ask them.
The initial moisture content will depend on storage conditions and the final moisture content will depend on your method of drying. Both can by checked with simple moisture content testers. The data sheet should give you the desired moisture content for proper processing and material properties.
10/31/2010 12:23 AM
yape i can understand!!!!
Sandip Shah
Register to Reply 2 comments
You might be interested in: Moisture Meters, PC Card Connectors, PC Enclosures
