Previous in Forum: What Is This Device?   Next in Forum: AM Radio, How Long Until It's Dead?
SMD Capacitors
10/31/2010 4:29 AM
how can i decode the small colored smd capacitors that has no mark on it ?
Re: smd capacitors
10/31/2010 8:45 AM
Test them with a capacitance meter if there is no label on the bag. If the capacitors are already in circuit then you should either remove them to test with the meter or perform an analysis of the circuit to get a transfer function and then measure the circuit response.
Popular Science - Weaponology - New Member Engineering Fields - Control Engineering - New Member Engineering Fields - Electrical Engineering - New Member
Re: SMD Capacitors
11/02/2010 12:23 AM
you can use a multimeter which can measure capacitance and easily measure the value of capacitance of a capacitor which has no mark on it.
knowledge is increased by sharing!!!!!!!!!!!
Register to Reply 3 comments
peterg7lyq (1); redfred (1); sajal mittal (1)
