Previous in Forum: lap Joint Flange   Next in Forum: Contact Resistance of Busbar Joints
Density of Mild Steel
11/02/2010 4:01 AM
i want to calculate the actual weight for my project....but this project have a big size. so i take a sample of mild steel to compare the volume then convert to actual size..as i know density = mass/volume(kg/m3). then i know the actual size for my project. so, if i know the mass and volume for sample then i can calculate the density. but the value of density is not same with standard density? should i calculate the density or just take the standard density for calculate the actual weight.
Re: density of mild steel
11/02/2010 6:25 AM
7850 kg/m3 or 7.85 g/cc or 0.2836 lb/in3 Should give you fairly cloase result.
Re: Density of Mild Steel
11/03/2010 3:20 AM
Mild Steel Density is 7850 Kg/m3.
