Previous in Forum: Replace Directional Valve Type Tandem by Type Float   Next in Forum: Coating Thickness and Number of Coats
Use of Stainless Steel Bolt onto the Galvanized Base Plate
11/02/2010 9:27 AM
Hi, All
i've use stainless steel bolt to secure the galvanised base plate onto graiting, putting different material does increase the corrosion, please advise.
regard
Re: Use of Stainless Steel Bolt onto the Galvanized Base Plate
11/02/2010 11:37 AM
Good Answers: 19
11/02/2010 4:45 PM
In most environments, stainless steel and galvanising won't suffer much additional corrosion due to them being in contact. It would be the galvanising that suffers if at all.
For corrosive environments (starting from marine environments upwards), the galvanising may suffer substantial additional corrosion and protective measures may be required depending on the life expectancy and usage of the object.
So if your situation is a simple factory situation (i.e. no corrosion around) or an inland rural or industrial situation, then the galvanising shouldn't be harmed and you would see it during the yearly inspection if it were to start rusting through.
A good standard I have used quite often is BS PD 6484:1979 Commentary on Corrosion at Bimetallic Contacts and its Alleviation. It is simple to use which is helpful in itself. You might be able to find it on the web somewhere.
This site was useful too for getting other articles: http://explorer.cekli.com/articles/pdf/bimetallic-corrosion
omw7
