Previous in Forum: Dispersing A Filler In Rubber   Next in Forum: Wastewater Treatment Technologies
Chelated Iron
11/03/2010 7:21 AM
Where can I purchase a small quantity(1 Kg) of pure chelated iron powder?
On line searches only turn up bulk quantities, or with added ingredients like plant nutrients.
Thanks
Re: Chelated Iron
11/03/2010 9:29 AM
Here's one place:http://www.bugspray.com/catalog/products/page1869.html
PRODUCT NAME: Powdered Chelated Iron.
PRODUCT DESCRIPTION: Dry powder form of chelated iron which
must be applied with a sprayer. This formulation contains a
full 10% chelated iron and is quite strong. Be sure to apply
it with a lot of water.
WHERE TO USE IT: On grass, flowers, trees, shrubs and
many other plants which are all listed on the label.
RATE OF APPLICATION: Use 1-4 oz of powder for every
1000 sq/ft you want to treat. Applications can be made every
2 weeks when using 1-2 oz per 1000 sq/ft; space treatments
to every 30 days when using 3-4 oz per 1000 sq/ft.
PACKAGING AND COST:
A 5 lb tub Coverage will vary depending on how strong you apply it.
At 1 oz per 1000 sq/ft, you will be able to treat
almost 80,000 sq/ft, which is almost 2 acres. At
2 oz per gallon, you will be able to treat 40,000
sq/ft, which is almost an acre. At 3 oz per 1000
sq/ft, you will be able to treat about 27,000 sq/ft
and at 4 oz per gallon, you will be able to treat
about 20,000 sq/ft (ITEM # 953278)
Re: Chelated Iron
11/06/2010 8:01 AM
