Previous in Forum: Connecting Cable Into the Switchgear   Next in Forum: Short Circuit Calculations for 2500A LV Switchgear Panel
Different Wire Sizes of Load Neutral and Ground
11/05/2010 9:16 AM
load 3sqmm, neutral 2.5sqmm and ground 1sqmm wires are used in my house to a 16amp socket(for 1000watt standalone water heater). wires lenght is 1/4 meter My electric system is singlephase 240volt. Is it dangerous?
Re: different wire sizes of load neutral and ground a problem?
11/05/2010 9:42 AM
2.5sq mm for phase and neutral and SWG 8 for ground or earth.
Re: Different Wire Sizes of Load Neutral and Ground
11/06/2010 11:15 AM
your water heater is standing alone 250mm near a distribution board??...it is dangerous.....do u have the cable size in the range of .5,1,1.5,2,2.5,3,3.5,4,4.5,6,6.5,7....................?
11/06/2010 12:18 PM
a wall socket installed of rating 16amp near db . the socket is used for heater wires from mains/isolater to socket(1sqmm ground wire, 2.5 sqmm neutral wire, 3sqmm load) different wire sizes used which are readily available at home is this kind of wiring dangerous? also i don't have bus bar these wires are tied together with other lines at isolator/mains
11/07/2010 6:12 AM
The Installation is not as per the IEC/BS regulations. wire size is wrong.!!!! about dangerous...say you can ride a motorcycle with helmet or without helmet. Which is dangerous???
11/08/2010 9:32 AM
It isn't wired to British Standard 7671, as there's no such thing as a 16A domestic socket in the UK.
So, what does the relevant national electrical safety code have to say about it?
A bucket of water is dangerous - one can drown in it!
