Previous in Forum: Communication Protocol - Microprocessor-Based Numeric Relays   Next in Forum: Circuit to Change Supply with a Button
Acquiring and Saving 17mbps Data
11/06/2010 3:26 AM
hello
suggest me the most effecient techniques to acquire and save 2 bits of data at 17mbps data rate
Good Answers: 82
Re: acquiring and saving 17mbps data
11/06/2010 7:52 AM
There's plenty of fast electronics around, but if you use two 8-bit shift-register chips to parallelize your data you'll have a 16-bit word to store every 8/17 = 0.47us, which is an easy task for all kinds of readily-available hardware, including a personal computer.* An example of such a shift register would be the 74hc164A, 65 cents at DigiKey (link).
* Hah, a personal computer running an operating system that doesn't periodically take control of the machine, but that's another story. A FIFO chip can help solve that problem, plus allow your program time to do data storage and housekeeping without paying attention to the input. An example of such a part would be IDT's idt7203 (link), which is 4k bytes long, able to buffer up to 2ms of your data. Both of these parts come in easy-to-use DIP packages, which is getting to be harder to find these days.
Thanks, Win
11/08/2010 12:36 AM
what do you suggest; if i use usb 2.0 with some microcontroller. will it be something more effecient and reliable.
Register to Reply 2 comments
