Previous in Forum: Acquiring and Saving 17mbps Data   Next in Forum: Surveillance Cameras Configuration
9 comments
Circuit to Change Supply with a Button
11/07/2010 11:47 PM
A 3v supply on my circuit can supply constant power to a component per time. i have two power demands(Components). i need to be able to interchange power from the 1st power demand(component) to a second power demand(2nd component) by pressing a button. i.e i want to be able to cut off supply from the 1st component and connect to a second component using a button and vice versa. what circuit can i use to achieve this. Thanks
Re: circuit to change supply with a button
11/07/2010 11:54 PM
You don't need a circuit. You need a switch.
11/08/2010 12:09 AM
A single-pole double-throw switch. (Or, if both legs must be isolated, a double-pole double-throw switch.)
Good Answers: 97
11/08/2010 12:09 AM
It can be done with a flip-flop and solid state or normal relays.
11/08/2010 6:27 PM
how can i get that done with normal relays! thx
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
11/09/2010 8:25 AM
Do a search on Flip-Flop circuits. You should be able to find a push-button type toggle circuit. Use flip-flop outputs to drive circuit suitable for driving a double throw relay. If you need more than that, then I think maybe you should find someone who understands circuit design to help with your project
Tom D.
11/08/2010 4:52 AM
yes, it is a switched lcd display driver
CR4 Admin - link removed - Please review Section 14 of the CR4 Site FAQ about advertising.
11/08/2010 3:14 PM
zerry,
You are a PITA! Your products are junk.
Good Answers: 299
11/08/2010 4:51 PM
Zerry, I agree with lynlynch. Your continued use of the site as a free advertising platform is shameful.
I see five of your seven posts are moderated out; the two remaining posts contain your website link, and have not yet been discovered.
Bad form, Zerry.
11/08/2010 6:49 PM
I reported him/her, scolded him/her via PM, and marked all his/her posts OT.
Register to Reply 9 comments
ajayi_adekunle (1); Doorman (1); Hendrik (1); lyn (2); tdesmit (1); Tornado (2); zerry (1)
