Previous in Forum: Sensor question   Next in Forum: ABB 800XA Training Manuals
Confused About a Power Meter
11/06/2010 4:43 AM
I am not an Electrical engineer.. But the other day I have seen a device just like the ampmeter which has 3 outlines which are connected to the 3 phase voltage. and this device would be able to measure the Watt... My question is that the given watt is the instant watt or what? because I was having a problem by comparing the watt number I had from this device and the watt which should be used for the factory
Re: Confused about a power meter
11/06/2010 6:58 AM
Yo there,
Does it look somewhat like this ?
It's a Phase sequence tester. To test if you have the correct sequence and rotational field on a 3 phase system.
T L.
Humans use 10% of their mind , WE take the rest
11/06/2010 7:14 AM
yeah exactly!! but it was measuring the kw ... it has an indicator which shows that it is measuring so
11/06/2010 7:29 AM
that's possible yes, whit an extra clamping part.
T L.
Good Answers: 151
Re: Confused About a Power Meter
11/06/2010 5:22 PM
What is a Watt? Potential (Volt) * Current (Amp) * power factor (Cosine of the phase angle between potential and current) The ability to do work. This is indeed an instantaneous value. The work done, energy. is the integral (sum) of power (watts) over time: Watt-Hours.
11/06/2010 5:48 PM
And ? what has this to do with the subject ?
gringogreg (1); therealabdo (1); timelord (3)
