Previous in Forum: DC/AC Solenoid   Next in Forum: Confused About a Power Meter
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
Sensor question
11/05/2010 3:19 AM
Dear all
Is that true when we say 2-wire sensor providing us 01 NO conact?
Is that true when we say 3-wire sensor providing us 01 pair of NO/NC contacts?
It means that we just need to connect the appropriate contacts to the control the load? There is not any consideration about the sensor power supply?
Could you let me know the symbol of these sensors to put into the diagram?
Regards,
Hien
Anything that can go wrong, will go wrong
Re: Sensor question
11/05/2010 3:54 AM
A 2-wire sensor with one NO contact is actually a switch.
A 3-wire sensor with a pair of NO/NC contacts is actually a changeover switch.
Who knows what they are connected to <rhetorical question>?
Re: Sensor question
11/05/2010 5:44 AM
PWSlack:
It is time pressure so I cannot start right at the first. It does not mean about switch. Let's consider it as capacitance sensor.
When we connect 24vdc 2-wire sensors, is that meant we connect negative point to the sensor then the output of sensor connects to the load (here means the coil, relay...). Is it possible to connect directly the sensor to power source?
The same question to 3-wire sensor.
Regards,
Hien
Re: Sensor question
11/05/2010 7:47 AM
hope this helps. (2-wire DC sensor as NO contact:blue to negative, brown to coil A1, coil A2 to positive.) (2-wire DC sensor as NC contact:brown to negative, blue to coil A1, coil A2 to positive.) (3-wire NPN sensor:brown to positive & coil A2, black to coil A1, blue to negative.) (3-wire PNP sensor:brown to positive: black to coil A1, blue to coil A2 & negative.)
Re: Sensor question
11/08/2010 9:54 AM
So the 2-wire sensor has three wires, and the three wire has 4? [Confused of Dodman's Lane]
Re: Sensor question
11/08/2010 9:52 AM
Please read the manufacturer's installation instructions for the device in question. If there isn't time to look at the instructions, then there isn't time to wait for a reply on CR4.
Re: Sensor question
11/08/2010 10:13 AM
RTFM. I concur.
Register to Reply 6 comments
hien.nguyenquoc (1); Leonf (2); PWSlack (3)
