Previous in Forum: What is the Purpose of Phase Angle in Transformers?   Next in Forum: 40W / 110V Copper Choke
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Technical Fields - Technical Writing - New Member
Effect on Primary
11/06/2010 10:38 AM
There is a Transformer of rating 13./6.6 KV, 10MVA, /Υ. If a ground fault occurs between one secondary phase, say r phase to ground then will it be sensed in primary() also either by Over load or instantaneous over load? Pls make me understand with necessary calculations.
Good Answers: 181
Re: Effect on Primary
11/06/2010 2:06 PM
Homework question?
It would appear so as you only suggest a fault on R phase.
You have to work it out yourself otherwise you gain nothing.
A quick scenario for you, your tutor asks how did you arrive at the answer, how are you going to reply?
11/06/2010 3:08 PM
Work it out here
Register to Reply 2 comments
