Previous in Forum: RL Switching Theorem   Next in Forum: How to detect Islanding condition in Induction generator ?
53 comments
DC DC Converter
11/08/2010 10:19 AM
My design is a DC DC buck converter using UC3842 IC getting 13.8v / 5A but I would like to get 13.8V/20A current. My input is 24v (max - 32v). Can someone give an idea how to derive a steady 13.8v with 20A current?
Below shown is my PCB design with silk:
Pathfinder Tags: convertor dc dc regulator
Re: DC DC CONVERTOR
11/08/2010 11:38 AM
Yeah, I'm sure that this is your design. That's why you have to ask somebody how to modify your design so that you can get a different output.
That's enough of a snarky comment to appease myself, for now. On to trying to be helpful.
It would be much more useful to be looking at a schematic with component designations instead of one side of a circuit board to identify what you must modify. First your supply that will be driving your converter must be able to provide at least 270 watts at 24 volts. If this cannot be done then nothing you do in the converter can fabricate power out of nothing. First the small bit of good news. You likely can continue to use the same controller chip. You may think that this will be helpful but this will likely be one of the lowest cost parts of the new assembly. Now for this to be a switching buck converter you must have somewhere in this design an inductor or choke. I do not see one on your board. So assuming that there is one external to this board, somebody will have to calculate how much energy can be stored in the magnetic field of that inductor. This will determine the speed that your controller will have to switch ON/OFF the current going into the inductor. If your controller chip cannot switch at this frequency then your inductor will have to be changed. You may find that the inductor will have to be changed anyway because the parasitic serial resistance of the inductor will dissipate too much heat at your 20 Ampere peak power output. (I won't bore you with the details about trying to design an inductor to meet your needs. It will likely be easier for you to identify first your needs and then finding a pre-made inductor that can do this job.)
Next you will have to identify the capacitors that will store energy by minimizing the change in voltage. (Oh, the inductor stores energy by minimizing the change in current.) As you may suspect, your design parameter of how much of a ripple voltage will be acceptable will be the key parameter that determines what the ideal capacitor value will be needed. Next you will have to consider the effect of a real capacitor instead of an ideal one. As you probably guessed this will also be the parasitic value of the ESR (Equivalent Series Resistance) of the capacitor. I noticed on the PC board that there are already several capacitors in parallel. This is a common method of reducing the effective ESR of the circuit capacitors by having several capacitors in parallel instead of one single capacitor.
Now you probably have a power MOSFET already on this circuit board. This will also have to be replaced because it is not likely that it can handle the higher current. You will have to identify the threshold voltage of the existing part so that the new beefier transistor will have the same threshold turn ON value. Oh don't forget, there are enhancement and depletion MOSFETs along with the designation of N and P channel. All of these must be kept consistent or the circuit cannot work. Now you can probably find that across the drain and source of your MOSFET there exists in the transistor a body diode. This diode though is located in the wrong part of the circuit topology to maintain the current flow that will happen through your inductor. Because of this you will find the fly-back diode that seems to be reverse biased by having the cathode connected to the node between the MOSFET and the inductor, while the anode is connected to return. This is the proper connection and must be a very fast Schottky diode capable of handling all 20 amperes of current. This too will have a few parasitic considerations but I don't think you want to know about them.
As you may have guessed by now, this is not a simple procedure when done correctly. You have also not presented sufficient information to permit a realistic redesign. You should also realize that I am insulted that you claim to be capable of doing the design of a DC to DC buck converter. You may have designed the artwork of this PCB but you did not design this circuit.
There are many application notes available made by control chip fabricators. I recommend that you look up the manufacturer of the the control chip selected to read up one of the application notes for that chip.
Re: DC DC Converter
11/08/2010 3:25 PM
Why you build such power supply while you can buy similar one for $20 ?
I build only thing not available for me in the market.
Re: DC DC Converter
11/08/2010 4:36 PM
I think there is limitation for Buck converter regarding the maximum power you can get out of it, 13.8V x 20A =600 Watt is too much and out of its limit.
I believe the maximum limit of it is about 150 Watt.
Why ,i don't know,don't ask me.
Re: DC DC Converter
11/08/2010 5:13 PM
First, 13.8V x 20A = 276W not 600W. Second, one can easily just purchase a 500W DC/DC converter. One can even buy a 5000W DC/DC converter if one really must have one.
Re: DC DC Converter
11/08/2010 5:43 PM
sorry for the error, i mean about 300Watt which is too much for Buck converter,500Watt and 5000 Watt are not Buck ,could be Full Bridge or some other topology.
Re: DC DC Converter
11/08/2010 11:53 PM
Oh I see now. You refuse to click on my links because you are certain that a 500 watt or even a 5000 watt buck converter cannot possibly be manufactured. Well I learned long a go to not argue with a fool that cannot face the truth. So go and run along in your anonymous fantasy world. Don't look at anything like a research article from Power Electronics Technology where a 100 kilowatt DC DC converter was made. Go along and live peacefully.
Re: DC DC Converter
11/09/2010 10:08 AM
Thanks for updating my knowledge,the information i had from text books may be 20 years old.
Now, could you tell me how come the Buck Converter power capability has been increased from 150Watt to 5000Watt during the last 20 years, what are the new parts that made that progress possible ?
Thanks again for updating my knowledge.
Re: DC DC Converter
11/09/2010 10:51 AM
The basic improvement has been from an increase in the current handling capability of transistors. I'm designing up a custom power supply design now that will control 500 amperes of current. 20 years ago the only semiconductors that could control this amount of current were silicon controlled rectifiers (SCR) that worked great for controlling when to turn ON but could not easily control OFF a flowing current. Today the current handling of a MOSFET has dramatically improved. One can also parallel a MOSFET for higher current handling capability. You will remember that if one tries to parallel a BJT without some complicated temperature measuring circuitry one doesn't get a real sharing because the transistor with the most heat dissipated has the lowest CE voltage drop. But a new switch topology has also been fabricated in the mean time called Isolated Gate Bipolar Transistor (IGBT) that combines several input impedance advantages of a MOSFET but with much higher amounts of current handling capability. There are several IGBT designs today that switch kiloamps of current.
To a lesser but not insignificant extent there has also been an improvement in core materials and fabrication over the years so that the higher switching frequencies used in today's switchers will have much lower parasitic core losses like eddy currents.
Re: DC DC Converter
11/09/2010 11:59 AM
Well, what about the large spike generated when the MOSFET turns off in case of Buck converter ?
Re: DC DC Converter
11/09/2010 1:05 PM
There should not be a large voltage spike if the fly-back diode turns on to maintain a current path for the inductor.
Re: DC DC Converter
11/09/2010 3:29 PM
Can you refer me to a good FET to be used with Buck converter 20-30 amp.
Re: DC DC Converter
11/09/2010 3:48 PM
Actually with only the single parameter of 20-30 amp drain current I can't give you a specific choice. But I went to Newark.com and this page of 30-40 amp MOSFET N channel transistors gave me a list of 440 different discrete transistors. Now you should also consider the threshold voltage, the VDS hold off voltage and the ON value of Rds to see which of all of these could be suitable. You should also indirectly consider the switching frequency to determine the suitability of the gate capacitance being charged and discharged by the controller.
Good Answers: 82
Re: DC DC Converter
11/09/2010 11:13 AM
As redfred said, it'd be helpful if you included a schematic. Yes, the '3842 is a widely-used classic jellybean converter IC. But it's best used for current-mode flyback, or boost step-up, rather than buck step-down conversion, especially when using only an inductor rather than a transformer. That's why there aren't any standard circuits in '3842 datasheets and app notes for high-current 24 to 14V buck conversion.
I see you like single-side PCBs. These create an interesting layout challenge, especially if you want to avoid jumpers, but a double-sided layout would give you room for fat traces, ground planes, etc., better suited for a high-power 280W design. I also see you like rows of paralleled capacitors, visually appealing? :-)
OK, to your question. Obviously you'll be needing higher currents in your inductor, so you'll need a bigger inductor, one with less inductance but with much larger wire and probably a larger core. If you can increase the switching frequency that can help keep its size in check, but it's still an issue. You'll need to run the MOSFET at higher currents, and you'll have 4x higher ripple currents, which means more low-esr capacitance. And your catch diodes will overheat. Fixing all this takes space your PCB doesn't have.
The bottom line is your nice little PCB layout will be toast. Unless, that is, you try plan B. Plan B is to use three or four of your little 5A circuits in parallel. Build more copies of your board, and place them side-by-side. Just think of all those rows of capacitors to admire. In this scheme each converter will have a slightly different idea about the correct output voltage. The one that thinks it should be higher shoulders the burden up to its current-limit, and then the next lower one takes over adding more current.
This brings us back to your circuit. As a flyback or boost converter the '3842 operates in current-mode control. In this mode its output appears as a controlled current source, and with a few extra parts it can also be current limited, which is good for parallel operation with other converters.
But you've set aside current-mode-feedback regulation, and are using the '3842 rail-to-rail output driver as a buck converter, adding an n-channel MOSFET source follower and freewheeling catch diodes. The circuit seems not to have any current limit, is that right? If your circuit uses voltage-feedback regulation, and the output is too low it'll just keep the MOSFET turned on longer, attempting to raise the voltage. That would be very bad for experimenting with parallel operation. TI suggests two voltage-mode circuits (page 15 of their 2002 app note), shown at right, but your circuit board doesn't seem to use one.
An alternate approach would be to forget tightly controlling the output voltage and use a fixed duty cycle. E.g., 58% of 24V is 14V, at no load. The inductor and output caps simply act as an averaging filter. If you use that approach you can safely parallel the outputs. But once again, if there's an excessive load, you won't have current limiting to help save your ass. Either way, you'd better add input fuses for protection.
The duty-cycle approach isn't bad. You showed us your PCB. OK, here's my PCB for a 300-watt step-down or step-up converter that works with 20 to 50V on the high side and 5 to 20V on the low side. It's basically a high-current adjustable-ratio DC transformer. For example it can act as a charge equalizer between 14V and 42V batteries. I call it a bus converter.
Cool, huh?
My circuit does have current-limiting protection, but I also have an automotive plug-in fuse on the board (upper left corner). I use two-phase conversion with an LT3782 control IC. The power parts are on the top (red) and the control parts are surface-mount on the bottom (green). There's an 8-pin uP socket (upper right corner) serving other functions.
Like you, I also have a row of capacitors to admire. :-)
Thanks, Win
Good Answers: 82
Re: DC DC Converter
11/09/2010 11:41 AM
Oh, sorry, I put up the wrong PCB. That was a 300W 14V to 42V converter, but one way (step-up) only.
Here's my adjustable DC-transformer bus converter. It uses an IR2085 to create the voltage-ratio duty cycle, and is rated at about 120W. It does have current limiting, but it also has a fuse.
The pic shows the power parts on the top side; the 4-terminal current-sensing resistor and the control parts on are on the bottom (not shown).
Thanks, Win
Re: DC DC Converter
11/09/2010 3:53 PM
Win,what is the name of that nice CAD software suitable for switching power supply design ?
Good Answers: 82
Re: DC DC Converter
11/09/2010 5:37 PM
I use Altium's PCAD, which they discontinued a few years ago, in favor of Altium Designer, which I'm learning. But I suspect most PCB CAD programs can do a pretty good job with switching-supply designs. The thing is, with all of them, you'll have to create your own custom parts. For example, I had to make inductors, fuses, 4-terminal resistors, etc. So one issue is, how hard is it to make new complex library items in your CAD program. There are a few other issues, like the easy of doing automatic copper pours, etc.
Thanks, Win
Re: DC DC Converter
11/09/2010 9:31 PM
For 24V DC/120V DC Boost coveter , what is maximum power can i get out of it for single unit ( without parallel connections) using today's available technology ?
Good Answers: 82
Re: DC DC Converter
11/10/2010 7:27 AM
If the "single unit" is a half-bridge or H-bridge off-line forward converter operating in continuous mode you can easily get to 3 to 5kW with a single transformer and the associate mosfet switches. But with a 24V rather than 340Vdc input, 5kW would imply over 200A, which is a bit much, so we'll back down to say 2kW max. Now, if you're asking, how much power can I convert with one mosfet and a simple flyback inductor, well, that's another story. Let's call it no more than 250W.
My 300W 14-to-42V converter pictured in the PCB layout in my first post, is a two-phase converter using an LT3782 controller IC, $9.63 at DigiKey, so each mosfet and inductor handles 150 watts. This is a current-mode controller, so paralleling outputs is fine, and if the sections are offset in time this reduces the output ripple current.
I suppose I could have pushed the design higher, but it seemed a sensible design. I de-rated it to 200W when used at elevated automotive engine-compartment temperatures. My biggest struggle was finding suitable low-esr high-temp output capacitors.
I see that LTC recommends their new $7 LTC3862 controller in place of the LT3782. See typical app dwg above. Introduced last year, it's suitable for use in multi-phase converter designs, nicely making a 4-phase design with two ICs.
They say it's suited for up to 12 phases. At 150W per phase, that'd be a 1.8kW converter, but I suppose you'd cry foul and assert the 6-chip 12-mosfet 12-inductor monster wasn't a "single unit."
Thanks, Win
Re: DC DC Converter
05/15/2014 12:56 PM
Dear Winfield Hill my name is mr Lim hadi from indonesia. Could you mind to inform me that I need dc to dc converter in 72Vdc to 12-15Vdc isolated and space pcb must not more than 150x70mm. If you can help me I will appreciate and thank you for it. Regards. Mr Lim
Re: DC DC Converter
11/11/2010 2:08 AM
Thank you for all, i just wonder regarding those replays, any way come to the point,,
now i added the schematic in that i am not used any fuse b'cause my equipment is highly sensitive that's why i use over voltage protector. my PCB and schematic not matched i know that .first i worked with common PCB, sure it is current mode design.
Good Answers: 82
Re: DC DC Converter
11/11/2010 5:25 AM
It's very hard to read your schematic (as I suppose you will see, trying yourself), because CR4 so badly downsamples submitted image files. But, peering at your PCB and dim drawing, I don't see a current-sensing resistor.
Wait a minute, is that a resistor in series with the catch diodes in your drawing (but not in your PCB layout)? Hmm, oops! Such a resistor would make a negative current-sense voltage, on the second, switch-off part of the cycle, both of which the UC3842 can't deal with.
But, wait! I can barely see the chip on CR4's copy of your schematic and it's not a UC3842, but an LTC part, an LT1242, is that right? Aha! Now this is getting interesting!! Even tho it's only an 8-pin chip, LTC has added some useful features over the original uc3842. For example, if you use an LT1242 instead of an UC3842, you can run it at up to 500kHz. Very nice, and well suited to increasing the energy you can get a small inductor to deliver.
But, wait again, I don't see that the enhanced LT1242 has the ability to work with negative CS on the OFF part of the switching cycle. Nope, sorry. So now I'm puzzled as to how your drawing could work, something is wrong. You really want a positive voltage on pin 3 during control-loop operation. LTC doesn't have an offset-voltage spec for pin 3, so I image some parts might seem to work with pin 3 = 0V, but whew, I dunno. Not good.
SFAICT, you still have a voltage-servo'ed output, not using current-mode, and no active current limit, so you can't simply parallel a bunch of your boards. BUT, depending on how your control is implemented (I can't make it out), you might be able to use one controller IC to control the rest of the boards, by routing a wire between them at the right place.
Perhaps you can send me a clean copy of your actual schematic by email, annotated if necessary, and I'll take a look -- winfieldhill 9at) yahoo (dot) com. Hah, that should confound the email harvesting programs! Also, an updated PCB image would be helpful.
Thanks, Win
Re: DC DC Converter
11/11/2010 6:27 AM
Thanks.... I have tried to send you an email with a clear schematic diagram along with comments. But the mail got bounced.. please advise your correct email id. Or you may just send me a mail at below id
mail at hifiworld dot info
Hope to get your reply.
Re: DC DC Converter
11/26/2020 5:08 AM
Hello....please, am trying to make the same converter, can I get the schematics on my mail.
Re: DC DC Converter
11/11/2010 9:16 AM
Please allow us to share you discussing the problem of mano's converter design and the way to solve it ?
Good Answers: 82
Re: DC DC Converter
11/11/2010 12:22 PM
Certainly. I studied the drawing and thought about ways to try using a UN3842 boost converter as a buck converter, and in the end realized it's a really bad idea. The lack of a proper positive inductor-current signal during the switch ON time is one problem, but another more serious one is that an n-channel mosfet can't be properly turned on, with a gate voltage 10V or so higher than its source, and hence its drain = 32V, so you need gate = 32+10 = 42V, etc. Once I realized that, I threw in the towel. The design might sort of work in spice, but in real life the mosfet will overheat.
See the post I just placed, at the end I wrote "What about current-mode buck converters? After a bit of thought, my advice is to just go ahead with a proper full-fledged current-mode buck-controller IC, such as an LTC1624 with an n-channel mosfet and a catch diode, or an LT3741 with two mosfets. The latter is better for high currents, since you won't suffer from the catch-diode drop and dissipation. Also, you can parallel multiple circuits to get more power, if you need."
Thanks, Win
Good Answers: 82
Re: DC DC Converter
11/11/2010 11:56 AM
"Wait a minute, is that a resistor in series with the catch diodes in your drawing (but not in your PCB layout)? Hmm, oops! Such a resistor would make a negative current-sense voltage, on the second, switch-off part of the cycle, both of which the UC3842 can't deal with."
The UC3842 and SG3842 series of current-mode controller ICs were advanced when they were introduced nearly 40 years ago, and have become quite popular in the years since. First, that's because the current-mode operation with cycle-by-cycle current limiting is a good type of regulation, and second because the part quickly developed many second-source suppliers, and look-alike and improved versions (I must have nearly 100 different '3842 files in my computer). This also meant the part has become very cheap, about 15 to 25 cents or less in quantity.
But one thing has always frustrated me about the world of '3842 types, which all have a current-sensing circuit like the one above: the voltage range is rather high, up to 900mV, and the comparator doesn't have a tight offset spec suited for lower sense voltages. This means the part wastes excessive power in the current-sense resistor for low-voltage designs (this isn't so bad for high-voltage off-line designs). Also, the part doesn't have a differential input.
But it's very cheap and ubiquitous, and works well, so one is motivated to fix the problem. My solution (right) is to add a low-cost single-supply op-amp to the circuit, amplifying the sense voltage and ameliorating ground bounce issues at the same time.
Like the UC3842, the LM358 is widely sourced and very cheap, under 10 cents, making a suitable companion. It can handle up to 32V for its supply, or better yet, power it from the UC3842's 5.0-volt reference output. If you want a smaller part with better accuracy, and prefer not to waste the unused 2nd op-amp, an LMC7101 is a good choice, a TLV2221 would be another. (The mosfet should have a gate-source resistor (not shown) to insure it'll be OFF if the UC3842 is unpowered.)
Thanks, Win
Re: DC DC Converter
11/11/2010 7:15 PM
Thanks for the good explanation,but practically which is better, should i run Buck converter in continuous mode or the discontinuous one ?
Good Answers: 82
Re: DC DC Converter
11/11/2010 7:26 PM
Ah, it's certainly a function of the exact voltages involved, but in general for power levels above 50W to 100W, continuous mode is a big advantage. Certainly at high power levels it's essential. As for the current/power mode threshold, in my case it's usually been a function of specific details like commercial inductor availability, etc. Let's hear from the experiences of others on this subject.
Thanks, Win
Re: DC DC Converter
11/11/2010 7:42 PM
Thank Win,i have another question regarding Buck Converter,can the Buck converter to be designed as a constant current source rather than as constant voltage source ?
Good Answers: 82
Re: DC DC Converter
11/11/2010 9:29 PM
Yes, indeed. I suggested a "full-fledged current-mode buck-controller IC, such as an LTC1624 with an n-channel mosfet and a catch diode, or an LT3741 with two mosfets," pointing out that both are current-mode controllers, which means they both run their control loops based on cycle-by-cycle current limiting. So in the middle-frequency region (just below their switching frequency) they naturally look like current sources (at very high frequencies they have large capacitor outputs, which of course means they look like voltage sources up there).
It's true that under normal use their low-frequency control loop seeks to adjust the cycle-by-cycle current to enforce a fixed output voltage, but that's simply because we take a pair of voltage-divider resistors from the output and hook this up to the controller's FB or VFB point. If instead we take say the LTC1624's current-sense resistor located in the drain of its top mosfet, and we hook up a difference amplifier or an instrumentation amplifier to it, we'll have an honest current-feedback signal. And if we connect that to the FB terminal, now we will have implemented a power current source.
Thanks, Win
Re: DC DC Converter
11/11/2010 10:41 PM
Thanks lot Win for your time and effort.
Regards
Good Answers: 82
Re: DC DC Converter
11/12/2010 3:47 AM
That's OK, thank you for the interesting questions. Y'all can just vote me a Good Answer for one or two of my detailed posts that were helpful!
I was looking at the Mouser catalog, and as long as we're talking about the 100W to 500W territory, but still looking for jellybean classic easy-to-get low-cost parts, I think it's time to start thinking about real controllers, with push-pull mosfet forward-converting transformers, etc. For example based on the UC3825 family. Or some of its offspring, like the ON Semi MC34025 (links).
Hey guys, it's really not that hard to hand-wind a transformer when its running at say 200kHz and has a small number of turns.
Thanks, Win
Re: DC DC Converter
11/12/2010 9:06 AM
I have an extra question please Win:
What are the advantages and disadvantages of using higher speed switcher ?
Good Answers: 82
Re: DC DC Converter, UC3842 buck, current-mode
11/12/2010 12:34 PM
"What about current-mode buck converters?" I have heard further from manojtm, and it's clear that he'd like to use an UC3842 controller IC for his buck converter application. This is possible, but it presents us with several problems to solve.
The first is that we need high-side switching, whereas the UC3842 gives us a low-side pulse (we can't simply use an n-channel follower, because we need to provide 10V gate drive). The second is that we'd like to preserve current-mode operation, so we need a way to measure the inductor charging current and present it to the IC. Alternately, we could use voltage-mode control (and give up on paralleling PCBs), which can be invoked by adding parts as shown in page 15 of TI's 2002 app note, see post #9.
We'll take up the gate-pulse issue first. In the drawing below I've added a three transistor level-shifter to create a negative gate pulse, so we can use a P-channel high-side mosfet switch. In this circuit the bottom NPN transistor acts as a current sink to create a negative pulse across its collector resistor. The two resistors should have equal value. The NPN + PNP emitter followers conduct high currents for rapid charge + discharge of the mosfet's high gate capacitance, ensuring fast mosfet switching.
Next we'll deal with the current-mode issue. The UC3842 wants to see a rising inductor current during switch-ON, which it uses to control the ON time and regulate the loop. We can use a trick, and provide this in a buck converter by sensing the charging current in the output filter capacitors. But we don't want much voltage drop in the process, because now this is output ripple we're talking about, so once again adding a current-sense amplifier makes good sense. :-)
Note how the output filter capacitors are divided into two parallel groups. One capacitor is used for filtering, with a series resistor Rs for current sensing, and the rest (e.g., 3 caps in manojtm's PCB) are for energy storage and filtering. This group of output capacitors also needs a series resistor, e.g., Rs/3, to insure a frequency-independent current-ratio for the two paths, e.g., 1/4 to the single cap and its sense resistor. This second resistor also acts to filter out the Rs current signal from the output. To work well, Rs should be larger than the capacitor's esr.
With this type of scheme, the UC3842-based buck converter will be operating in current mode, with a maximum current limit at about Vs=50mV for G=20, and Icharge = 4 / G Rs, or 10A peak for Rs = 0.02 ohms. Multiple circuits can be paralleled to get more power.
Or, as mentioned earlier, we could use the UC3842 in voltage-mode.
I know this looks complicated, but that would be one motivation for using a more advanced PWM controller IC. OTOH, the UC3842 only costs 25 to 50 cents in volume (dramatically less than other controller ICs), and the other parts are also very cheap. All parts have multiple sources.
Thanks, Win
11/13/2010 10:17 AM
Here is the house of SMP's experts,i need your help:
I'm working on 1kw push-pull switching power supply design , I'm looking for suitable 2 heat sinks for the unit and to refer me to a supplier.
Thanks for help
Good Answers: 82
Re: DC DC Converter, UC3842 buck, voltage-mode
11/14/2010 8:36 PM
"Or, as mentioned earlier, we could use the UC3842 in voltage-mode."
SFAICT, manojtm's application involves a 24 to 32V voltage-stable battery power source, powering a 13.8V transceiver with a wildly-varying current load. Current-mode controllers are good at isolating input-voltage steps (not a problem here), but not so good at dealing with transient load-current steps (a problem here), since they want to momentarily keep on delivering the same current. So it would appear voltage-mode control is preferred. The only problem with voltage control is difficulty in paralleling the outputs, which means we'll have to work until we have a single 300W version of the power supply.
Following the suggestions in TI's 2002 app note, slua257 (link), see post #9, we've sketched a candidate voltage-control-mode buck-regulator circuit. (TI suggests using their UCC38C42 version of the '3842, which looks worth looking into.)
We've used the RC OSC pin, isolated with an emitter-follower, plus a resistive divider, to drive the CS current-sense control with a 900mV peak ramp, simulating a rising inductor current.
We also added an inverting level-shifting gate-driver for a proper P-channel MOSFET buck switch. The driver is fast and can source-sink about 0.5A into the FET's gate. Note how the level-shift circuit uses a current sink, so a fixed-amplitude gate pulse is delivered to the mosfet, independent of the Vin voltage, from 22V or so up to over 50V. The rest of the power circuitry is conventional.
The control-loop compensation looks complicated, according to TI, but we don't need a particularly-fast feedback loop, and as a result we can no doubt simplify the circuit.
If we want to go for broke and create a single 300W buck converter, the pressure will be on us to find a suitable 20A inductor (or paralleled inductors), MOSFET and Schottky diodes, and low-esr input and output capacitors.
One big bonus, no awkward 2-milliohm 1-watt current-sense resistor!
Thanks, Win
Good Answers: 82
10/19/2013 12:33 PM
A reader, Raffy, pointed out that the regulator ICs have a 16-volt UVLO under-voltage lockout. So the 12V zener diode will prevent the circuit from working. The zener is only needed if the input voltage can go above 25V for the LT1242 (or 30V for the UC3842), and if used it should instead be say 20V (or 27V). Alternately an UC3843 with a 9V max startup lockout could be used.
Thanks, Win
Re: DC DC Converter
11/10/2010 8:56 AM
"with one mosfet and a simple flyback inductor, well, that's another story. Let's call it no more than 250W."
That figure '250W' is very close to what i said about the maximum power capability of single Buck/Boost convert, 150 Watt 20 years ago and now 250 Watt.
Re: DC DC Converter
11/10/2010 9:16 AM
Why not a several MOSFETs in parallel can increase Buck/Boost converter capability to much more than 250W for a single unit ?
Good Answers: 82
Re: DC DC Converter
11/10/2010 12:12 PM
It isn't just the mosfets, it's the inductors, the freewheeling diodes, the filter caps. The discontinuous current, the high peak currents, the capacitive switching losses, the driver losses. Pretty soon one realizes there are better configurations to put one's energy into. Or at least to make the inductor into a transformer with the ratio picked to equalize the charge/discharge times. But once one moves to a transformer, one is ready for half-bridge, H-bridge, or other better circuits.
Thanks, Win
Re: DC DC Converter
11/10/2010 3:39 PM
Agreed, MOSFET current handling capability is but one aspect of all of the other parameters that must come together for any buck converter design to be feasible. Also 250W is a good rule of thumb for an upper limit for a single stage buck converter. Higher amounts of power will be much more easily designed using different circuit topologies. But I don't believe that 250W or any number near this is the theoretical power limit for a buck converter.
Re: DC DC Converter
11/10/2010 4:50 PM
I consider Buck/Boost converter is the most ever reliable converter, but unfortunately its power handling capability is limited to about 250W.
Good Answers: 82
Re: DC DC Converter
11/10/2010 5:07 PM
"once one moves to a transformer, one is ready for half-bridge, H-bridge, or other better circuits"
Let me add single-ended forward converts to the list. This is probably the most popular next step among low-cost high-volume manufacturers, such as for mini-tower computer power supplies. These are almost as simple as a flyback, in terms of parts count, but make much more efficient use of the magnetics. The transformer is not an energy-storing inductor with a secondary winding, but instead a proper power-transferring transformer. As a result the transformer is smaller and cheaper, even if it may have an extra winding and diode to reset the core's flux. An output smoothing inductor is also required, but it's small and one still wins in the magnetics budget. Peak currents are lower, and output capacitors last longer (or they can be cheaper).
Thanks, Win
Re: DC DC Converter
11/10/2010 5:19 PM
Very neatly summed up. I bow to the master.
Re: DC DC Converter
11/14/2010 9:45 AM
Up to this moment 178 viewers have seen this thread only "two" of them shared with information and the rest preferred to take information only and not to give any thing.
Amazing !!!
Good Answers: 82
Re: DC DC Converter
11/14/2010 3:05 PM
185 viewers now. It's not clear how many found the subject interesting once they landed here.
Well, it's a rather esoteric subject, how to make a buck converter from a jellybean boost converter IC, and push it up to 300 watts. It continued in part because I found the idea intriguing, and because the O.P., manojtm, has a special interested in using the UC3842, and continued with offline email questions and encouragement.
At any rate shortly I'll make at least one more post to advance the topic towards a satisfactory finishing point, in my mind at any rate. Or maybe manojtm, or someone else, will have more to say, sparking further posts. That'd be fine. It'd be nice to find out how it all works out.
Pictured, 8-pin and 14-pin versions of the UC3842.
Thanks, Win
Re: DC DC Converter
11/14/2010 5:32 PM
Mr. Hill,
I hope you won't mind a truly excessive gush towards your work in general. For many years I've admired your work in your textbook "The Art of Electronics". I am personally ecstatic and humble that you have joined us at this blog. The number of non-contributing viewers to this discussion is a testament to your brilliant insight to the esoteric and fundamental world of analog electronics. While my career and education happened to have never used this textbook, my career has constantly exposed me to your work in this text.
I thank you for your work and look forward to any further comment on this thread.
Redfred
Good Answers: 82
Re: DC DC Converter
11/14/2010 6:51 PM
Well, thank you indeed for your kind comments. I have enjoyed reading your contributions here as well, and marked GA on a number of occasions. I enjoy exploring electronics-design issues anytime there are others also interested. I've been an active participant (5 to 10k posts, you can read them with Google and see) well into my second decade on the usenet group, sci.electronics.design, but that's ASCII only, whereas the html format here allows one to post links, figures, special characters in formulas, etc. I'm just hopeful of finding more interested parties.
I did suggest to the CR4 managers that they initiate an Electronics Engineering, or Electronics Design group, in addition to this Electrical Engineering group. (Electrical Engineering is better suited to high-power electrical issues, which is interesting as well, but Electronics Engineering is somewhat different.) Anyway, they didn't listen, yet.
As an aside, it's also possible that one of these discussions may lead to a topic (or a "good circuit" or a "bad circuit") we place into H&H AoE III, which we're spending most of our time working on these days. Hah, maybe this one will result in something!
Thanks, Win
Re: DC DC Converter
11/26/2010 1:50 AM
hi, win i completed my project . i tested 16A load with my circuit wow !!!! it can handle more than 20A or more if you use IRFP4668 MOSFET anybody interested i will post my final circuit thanks all
Good Answers: 82
Re: DC DC Converter
11/26/2010 9:11 AM
Yes, indeed, we're still interested. Please post away! What frequency does it run at? Tell us about the inductor(s), etc. The IRFP4668, $8 at DigiKey, very good. But maybe you don't need a 200V part - a lower-voltage part with the same RDS(on) will have less capacitance.
But Manoj, after you place the post, check to see if you can read the drawing. If not, divide the figure into two pieces and post both of the new pieces as well. Note, when you make a post, you have 15 minutes to edit it and repost, and only the final post shows.
Thanks, Win
Re: DC DC Converter
05/15/2014 12:26 PM
Dear Sir My name is mr Lim hadi from indonesia. Kindly inform me your dc dc converter? Appreciate and thank you for your attention. looking forward your reply regards Mr Lim
CR4 ADMIN - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Re: DC DC Converter
05/16/2014 11:55 PM
Manojtm , I want your complete project with irfp4668.thk
Re: DC DC Converter
11/10/2010 9:43 AM
I don't understand the purpose of finding out the maximum power capability of a single stage Buck/Boost convert. Certainly there are practical limits that one will find for most applications. But there will also be rare application exceptions that far outstrip common application power levels. A few possible scenarios involve DC power transmission/distribution, PV solar cell utility, a variety of Physics experiments, electroplating, and I'm certain a plethora of esoteric uses that I just cannot think of now.
Register to Reply 53 comments
Anonymous Poster (12); IYKEEH (1); manojtm (3); ptwsjb (3); Ragab1952 (1); redfred (10); Winfield Hill (18); Zeko (5)
