Previous in Forum: Turbocharger Manufacturing   Next in Forum: Anyone Know Where to Get a Drive Dog?
Difference Between Pneumatic Pressure Gauge and Hydraulic Pressure Gauge?
11/10/2010 5:39 AM
Can we use same pressure gauge for pneumatic and hydraulic applications?
Case:
We are using the test rig for checking the leak in the assembly. The leak will be checked by means of pneumatic and hydraulic by using compressed air (10 bar) and RO water (20 bar) respectively.
The result should be "No leak" in the assembly and "No pressure drop" in the pressure gauge. Can I use the same pressure gauge for both the applications? Is there any difference between pneumatic and hydraulic pressure gauge?
Please advice.
Re: Difference Between Pneumatic Pressure Gauge and Hydraulic Pressure Gauge?
11/11/2010 1:09 PM
I can't think of a reason you can't.
11/12/2010 5:59 AM
Sir,
I am not able to understand your reply.Kindly explain.
12/01/2010 12:51 AM
only by design, fluid dynamics 101, air is a fluid, so technically both are hydraulic, hydraulic gauges normally go to much greater bar levels because of industrial equipment relying on hydraulics for heavy lifts/applications and air will find a leak before oil.
Regards
Archie
Enerventure
Register to Reply 3 comments
Anonymous Poster (1); Labyguy (1); saravananpg (1)
You might be interested in: Pressure Gauges, Pressure Sensors, Pressure Switches
