Previous in Forum: Procedure for 5 way Manifold Valves in DPT   Next in Forum: Kane May Flue Gas Analyser 9106
Belt Scale Calibration Procedure
11/10/2010 9:34 AM
Anybody can help me about calibration procedure of Belt Scale which measuring the coal flow over a running conveyor belt. It has also a tachometer to measure the speed of the conveyor. There is a totalizer which integrate the information from the loadcell and tachometer pulses to get the total accumulated coal that is being transfered. I am told by my Boss to make a calibration procedure for: 1. Tachometer calibration 2. Auto Zero Cal 3. Auto Span Cal using static weights I am new in the field of instrumentation. Your heartily response for this subject would be highly appreciated. Thank you guys.
Re: Belt Scale Calibration Procedure
11/14/2010 6:42 AM
hello
this procedure we in here the cement plant for the raw material i think it will be the same
1- Adjust zero of the belt scale:
· Clean belt scale weighting system.
· Operate belt empty and adjust output zero setting to be 4 mA .
2- Adjust span of the belt scale:
· Carry the belt test weight from the cal. rod to weighting rod.
· Operate the belt with the test weight and adjust span.
· Operate this procedure from zero to span till the measuring is from 4- 20 mA adjusted.
3- Weight Check :
This is done if there is the possibility and the access to do this check :
· Fill the hopper by the desired material.
· Withdraw material until making the counter reading without fraction.
· Record this counter reading.
· Withdraw material until certain reading of the counter (such as 10 tons).
· Record this new counter reading.
· Check this weight actually by other balance scale.
· Account the error
error = actual weight - counter reading
After this weight check we can measure if this zero and span calibration is ok or we still have another difference.
Note : The weight check may done before zero and span calibration
Reply to Forum Thread
You might be interested in: Flat Belt Pulleys, Calibration Instruments
