Previous in Forum: GI Pipe Welding   Next in Forum: Cooling Load
Conveyor Belt
11/11/2010 2:12 AM
What is the difference between NN and EP belt??. We are having all belts with the EP construction if we want to go for NN belt since the cost of NN belt is less, then what are all the changes I have to do in my system and what will be drawback.
Up to my knowledge, I have seen most the pipe conveyor with EP construction. If it is so, what is the reason behind it?
Good Answers: 266
Re: Conveyor Belt
11/11/2010 11:00 AM
The NN cloth backing is woven from nylon fibers. The EP from Polyester fibers and Nylon. The NN will stretch more. Nylon is more forgiving in applications where the belt takes a impact.
You might be interested in: Flat Belt Pulleys, Conveyor Controls and Monitors
