We have a concrete containment area (pad) measuring about 30' x 150' located outside that has several low spots/dips that are very effective at collecting rain water in areas away from our current sump pit. While a nuisance in the warm months, this can create a slip hazard during winter (fast approaching) when the water freezes (we are in the midwest where temperatures average in the 20's in the winter and usually drops to near 0 for about a week). There are several storage tanks with support legs on the pad so we have a lot of obstructions to work around as well. In addition we will typically get up to 12" of snow (at least the last several years) over 2-3 snowfalls which is hand shoveled as well as possible given area obstructions. We have used ice melt and traction sand to cover the areas but ideally we would like to eliminate the pooling by selectively increasing the pad elevation 1-3" in areas (with the target being to do so without causing the problem to move elsewhere).
We have tried to surface coat the low areas with concrete patch and a couple of different types of epoxy fillers (Belzona manufactured one, sorry but I don't have the product information in front of me) but in all cases the materials have delaminated from the pad surface. The concrete is finished/textured similar to a sidewalk so there is some "grip" but we have not gone to the extreme of scarifying the surface to make it extremely rough.
We have also considered trenching from a couple of the lowest areas to a new sump pit to drain away water however one concern is that this will just point out the next low spot.
Has anyone had good experience with a top coating material that can withstand freeze/thaw cycles and stick with application thicknesses tapering from grade to as thick as 3"?
Thanks in advance for any suggestions.
