Previous in Forum: Topic for Ph.D   Next in Forum: How to EDM a Spline
15 comments
Rolling a Radius in Light Steel or Aluminum
11/12/2010 9:32 AM
I have a need to roll a radius in either 3/16" aluminum plate or 1/8" mild steel.
The pieces would be 40cm long x 20cm wide and 40cm long x 10cm wide.
I need to go from a flat 20.5cm to a 20cm ( measured inside the piece) and 10.5cm measured flat across to 10 cm ( measured inside the piece after the radius is put in.)
Is it possible to use a sheet metal brake to put a curve in these sheets by taking little bites?
What size brake would work?
I contacted a dozen machine shops and they told me that the peices were either too small to fit in their rollers or they did not want to deal with such small pieces . So, as usual, I am going to do this myself if I can get the right tools and the cost is not too extravagant.
I have a roller that we use for heavy wire cages, but the rolling pins are too far apart to catch the 20cm pieces.
Any ideas are welcome.
Re: Rolling a Radius in Light Steel or Aluminum
11/12/2010 10:10 AM
r=? Maybe this is intuitive to smart people.
I'd rather try to roll 1/8th inch steel.
Mixing units gave me a headache.
You might get away with a brake, depending on how smooth the r needs to be. I don't think the size of the brake matters. If you stack two pieces on top of each other, you'll get a nice radius on the "outside" piece, even using the brake.
Next.
11/12/2010 10:15 AM
Lynn,
Actually, the little 'bend marks' on the steel would help the water to grab hold and push harder as opposed to a slick surface.
thank you.
nm
11/12/2010 10:44 AM
Virtually any sheet metal shop with a press brake should be able to do this. Successive small bends like this are sometimes called "bumps." If accuracy is needed, it can all be calculated; otherwise it can be basically a repeated freehand operation.
11/12/2010 2:42 PM
T,
Any idea what kind of a brake would do 1/8" steel?
Could it be done on a smaller , hand type brake or is hydraulics involve3d?
Thank you.
Good Answers: 114
11/13/2010 12:45 AM
You could use longer/wider pieces & cut off the excess
any chance of cutting some sections out pipe
you can probably rig something similar to what is used to bend flat bar [or round] for decorative iron fencing
A fence guy may even be able to do it for you
11/12/2010 4:10 PM
Since you're bending the long way, you probably need more than a hand brake or roller. However, you might be able to use an ordinary hydraulic press, lay the workpiece in a channel of suitable size, and press down in the middle with a piece of pipe of the right radius. I'm not familiar with the arithmetic on tonnage, though.
11/13/2010 5:38 AM
To solve this problem using what you have available, you can cut the strips long enough with a guillotine, to get say 4 pieces, from each strip, then roll the long strips through your rollers, that you mentioned in your post, then cut them to the required length, with a hand held grinder, fitted with a 1mm stainless steel cut off wheel.
The other method you have been offered as a solution, of many small breaks, on a brake press, will give you a very difficult job, if you want to get a nice looking finish.
The brake press needed wil have to be either hydraulic, or power operated by some other means and this will cost you a lot more time and or money to get a result.
Free advice is always cheap !!!
11/13/2010 11:52 AM
try purchasing a small manual roll of 50 to 100 cm
surely it will do the job
and not that expensive
you may find it at a large supply shop nearby
or even purchase it online for a few hundred dollars
11/13/2010 7:03 PM
Something like this? I seem to remember seeing them a little cheaper but I don't recall where.
Nothing exceeds like excess.
Good Answers: 179
11/13/2010 11:58 AM
You need to use either an "English Wheel", or a "Planishing Hammer" with the proper radius dies in order to produce a slight curvature in your sheet metal that you desire. Using a sheet metal brake may produce very defined and crisp bends that you may not like...
Good Answers: 130
11/13/2010 9:02 PM
Captain:
They're tools used for body building (A.K.A. coach building), as in forming and dressing car panels, or aircraft curvy bits, medieval armor - 3D sheet metal creation.
the bottom bit, in this 'original art', is a "stake"
Nowadays machines are used in custom work and 'panel beating'.
If this is what you were recommending the parts you have 'not quite right', as they rely on the operator guiding the work and 'distance' for safety.
If Netmaker tried using one on his size job - he'd probably 'nibble off' his fingers.
And 1/8" is hardly sheet metal
He'd be hard pushed to find one capable of over 16 gauge (1/16")
So should I now paraphrase your 'attitude' when some totally unqualified person offers 'dangerous advice' ....
Good Answers: 130
11/13/2010 7:49 PM
I presume these are some existing thing you are modifying and you have many to do Y/N?
If Y; then I would find a bit of bar the right inside radius, and a bit of heavy angle, and make a press tool to fit a 3 ton fly press.
You may need to put a bit of die rubber in the angle to keep the lead of the bend "brake" against the top tool (the bit of bar)
You could also get someone to machine the bottom die to your radius.
That done you can bang them out as fast as you can load and swing the press.
I don't think rollers can do it - other than 'forcing it in' - which is 'bad practice' for the machine.
11/13/2010 9:18 PM
Roll formers come in many sizes. I've seen one, a horizontal type, in a structural steel fab shop that bends large, and I mean laaarge, I beams for bridge arches. One that can handle 1/8" steel or 3/16" aluminum shouldn't be too hard to find for a reasonable price. As long as this isn't a one time use, it might be worth the investment. The one I linked to can handle only 18 ga and is held in a vise. Light duty for sure. Auto body type equipment. That company also has a little bit larger ones at their stores, if you are lucky (or unlucky) enough to be near one. Bring someone with you that hates tools to hold on to your credit card. Ask her for a valium before going in. And a strong leash would be a good idea too.
11/13/2010 9:44 PM
I checked and nothing they carry does more than 18 ga. Keep looking for a fab shop or blacksmith (there is actually a welding shop near me that still does blacksmithing for decorative wrought iron railings).
Good Answers: 130
11/13/2010 10:27 PM
I think you will be up against the basic geometry of roller length/strength, and so diameter, for this thickness of material.
Also meaning you can only roll the center bit and have two straight bits either side, so it's not much different to a press in the middle with a large radius blade.
But I now think I was under on the tonnage for 400 mm length, so it might be better to have a tool made to suit a local press or press-brake.
More expensive than fabricating out of junk at hand, but .....
Register to Reply 15 comments
34point5 (3); Anonymous Poster (1); Bob 6x6 (1); CaptMoosie (1); Garthh (1); Jaguar (3); lyn (1); netmaker (2); Tornado (2)
