Previous in Forum: Nut and Bolts   Next in Forum: Safety Techniques - Cogeneration Plants
9 comments
Gas Lift Support Springs on Trap Door
11/12/2010 6:27 PM
i am installing two gas lift support springs on a trap door. i looked at several web sites to see which end of the spring goes up and i receive conflicting info, one says up, another says down. can anyone please tell me if the black cylinder or the shiny piston rod goes up... or tell me if the black cylinder or the shiny piston rod goes down. No no or yes answers, please.
Re: sailmail
11/12/2010 6:37 PM
Depends.
Re: sailmail
11/12/2010 6:54 PM
To add to the last answer, look at the support springs and look at your trap door. Do you want them to assist in opening the door or closing the door. It depends.
Like a moth to the flame, here I am again.
Re: sailmail
11/12/2010 7:11 PM
There is a dab of oil inside. By putting the rod downward, the oil bathes the internal rod seal. If you were to put the rod up, the oil would drain away from the seal, drying it out and failing to lubricate it.
Re: sailmail
11/12/2010 7:33 PM
Makes sense to me. GA
Good Answers: 266
Re: sailmail
11/13/2010 12:13 PM
Some of what you say is true as far as the oil helping to lubricate. That's not why the oils there though. It's there to dampen the swab when it reaches full stroke. Instead of it impacting on the end it hits a cushion of oil. Will not matter which way its mounted in normal use the oil is circulated around enough to lubricate.
Have seen many mounted with the rod up.
Good Answers: 123
Re: sailmail
11/12/2010 8:27 PM
By a far majority, I see these struts installed with the rods up. But the comment on the oiling makes a lot of sense to me.
Bob
Re: sailmail
11/12/2010 8:37 PM
I got this application advice from McMaster-Carr, which sells several types.
Re: sailmail
11/12/2010 8:49 PM
Perhaps we are confusing gas springs with "gas" shock absorbers.
Oil filled devices (shock absorbers) should be positioned fluid down. Gas filled devices (springs) should be positioned rod down.
Re: sailmail
11/12/2010 9:23 PM
Good point. Perhaps guest would consider giving a few more clues.
bob c (1); kramarat (3); lyn (2); ozzb (1); Tornado (2)
You might be interested in: Piston Pumps and Plunger Pumps, Flat Springs
