Previous in Forum: Arc Furnace Transformer   Next in Forum: Motor Connection - Ladder Diagram of Star Delta
Motor Theory
11/13/2010 5:40 AM
hi can anyone give me a help with this question please?
i need to find starting voltage of the motor, the percentage of normal torque when the motor is started the motor start current and supply current.
i thnk the point of the exercise is to bring home the point that that trfx for starting reduces the torque at starting by the turns ratio?
i have calculated the motor current but not sure what to do next.
The 5 factors are voltage, current, Ö 3, power factor, efficiency.
Im = power rating kw x 1000 / Ö 3 VL x eff x pf
= 30 x 1000 / Ö 3 x 415 x 0.85 x 0.8
Im = 61.5 amps.
any advice appreciated.
Re: motor theory
11/13/2010 8:29 AM
But in a Sterling cycle motor there is four phases and not three.
My answer above may seem to be off topic but it does make my point. Most three phase electric motors are induction motors, but there are other motor circuits you might have. You must know many other factors of the motor circuit and geometry to calculate the expected results. The forces, currents and voltages are of course established by the very cryptic collection of Physics equations assembled by James Clerk Maxwell. These equations and the information you provide allow an engineer/physicist to predict the magnetic field generated by the stator windings. But to know the force this will impart on the rotor from a theoretical analysis you must know the magnetic field generated by the rotor. The easiest to calculate is the synchronous motor that has a DC current driven through the pole windings of the rotor circuit. To calculate the rotor field generated by an induction motor one must know either which standardized set of squirrel cage designs one has or go through multiple iterations of Maxwell's equations to get a suitable set of equations. Tesla received his patent for the induction motor in 1888. Over the years the squirrel cage rotor design have been empirically optimized for a variety of different load conditions. NEMA listed many different styles but today the most used ones are the A,B,C and D rotors.
Few people have the patience or need to go through all of this mathematics. Most people just look up the motor torque capability curves from the manufacturer. I do not know of a manufacturer that theoretically derives these curves but possibly there is somebody. I expect that most empirically measured their motor responses once and spot check all products at key speeds and loads.
Re: Motor Theory
11/15/2010 9:55 AM
The torque of the motor is determined by the inertia of the mechanical load and the time it takes to run-up to speed.
Good Answers: 804
Re: Motor Theory
11/17/2010 12:45 PM
AC motor output torque, at a fixed frequency, varies by the square of the voltage reduction. So for example at 50% voltage, the torque is reduced to .5 x .5 or 25% of rated, at any point on the torque-speed curve.
But how that relates to starting a LOAD is totally dependent upon the characteristics of the load and the rate at which you need / want to accelerate it. This is also part and parcel to the current requirements etc. etc. It is not simple, but there are tools to help you do it now.
Is this a classwork assignment or do you have a real-world issue to solve?
Register to Reply 3 comments
JRaef (1); PWSlack (1); redfred (1)
