Can anyone help me out with a good formula for figuring the section modulus of steel tube with radiused corners. I have the formula for a hollow rectangle out my AISC steel construction manual but it does not account for the radiused corners. I am trying to build a spreadsheet for some of my calculations and I want to plug in a good accurate formula or possibly 2 step formula to figure the section modulus for square and rectangular steel tubing. I can get close by subtracting the square corners and then figuring the section of a pipe with the same radius as the tube corners but its just not the same. I know there are some clever people out there. I know this is useful to more than just me. I typically use the numbers from the book but as I would like to build this spread I need it to figure the section on the fly. Can anyone guide me? I will share the spreadsheet with all...
Thank you,
Thomas
