I am looking for a commercial, liquid, sound damping/vibration control material for application between two male/female fiberglass components.
The material could be described as an extremely dense polyurethane that maintains a rubber consistency after setting up.
The area of application cannot be reached directly for the placement of a mat.
Products similar to what I am looking for are used in the manufacture of automobiles as a sound deadener, where the rubber-like material is pumped into the automotive frame. I would like to pump the material into the area where it is to permanently reside.
The material will be approximately one inch thick and needs to cure in place between the two housings.
Do you know what material/manufacturer I should be looking for? Do you have a URL/link to the website?
Thanks.
