Previous in Forum: Battery Pack for Warm Hands... Ski Glove   Next in Forum: Electric Shock
10 comments
Battery Capacity
11/16/2010 6:53 PM
Dear CR4's
Is there a practical way to find out the up to now capacity of a used battery ?
Thanks for your animated ideas in advance.
Re: Battery Capacity
11/16/2010 6:59 PM
11/16/2010 10:50 PM
Yes there is.
rcf-jr - If there was anything hard in life, there would be a lot of people out of work.
11/17/2010 10:15 AM
If by measurments ,the battery capacity is 80% of its original value when it was new, does this battery still healthy battery ?
Good Answers: 32
11/17/2010 11:54 PM
That depends on the battery chemistry.
For Lead Acid I'd say yes it's still pretty healthy. For most Lithium batteries I'd guess about half it's service life. For others ????
johny451
11/18/2010 2:15 AM
Any test of any battery or cell must have batt /cell fully charged- the majority of chargers over charge the batt/cell which heats up & reduces life- the best charger which I use for recharging wla,sla,gell I adapted from a 300w atx surplus computer power supply- basically extra resistors are added to 5v & 12v feedback to pin 1 TL494 or equiv to get chip PWM to output 14v &6v- constant voltage charge - a voltmeter & ammeter are added- the batt/cell stays cool- & full charge is obtained(when the ammeter drops to almost zero)- a visual indication as used in some batts is removed & used as portable hydrometer for each cell of wla batt- often there are 5 cells f/c & 1 under- can change electrolyte- usually it is end cell near neg post- to store fully charged wla batt- tip out electrolyte!- into bucket- will be sludgy- dry charge batt now will store for months- when ready to use batt add filtered orig electrolyte or new- will give extra years of life.
11/18/2010 2:56 AM
Oh rating is not called, ghhn battery over 10 years of age then the lead sulpher is the negative post attracted however there are new gel types.
11/18/2010 11:33 AM
Do you mean to store a battery for long time you must remove the electrolyte from the battery ?
Good Answers: 32
11/18/2010 5:13 PM
Not must - he is just saying that it is a good idea.
johny451
11/18/2010 5:26 PM
Thanks for clarification,but where from i can buy new electrolyte ?
The store sells only battery !
11/19/2010 1:27 AM
The electrolyte used in wet lead acid batts is sulphuric acid with added distilled water(or clean rain water at a pinch, or melted ice water from fridge) to obtain a specific gravity of 1.260 @ 20' C- use hydrometer to check.
Anonymous Poster (4); Johny451 (2); lyn (1); Neil Kwyrer (2); rcf-jr (1)
You might be interested in: Battery Holders, Battery and Fuel Cell Components
