Previous in Forum: Wafer vs Lug Type Butterfly Valve   Next in Forum: Multipipe Slug Catcher Design
What is Name, Code of the Pump
11/17/2010 7:29 AM
Good day sir.
I got the problem with my PUMP. I don't know the name of manufacture or model code of the pump. But I am sure this is the piston axis pump, diameter of piston maybe 25 mm.the number of piston are 9. The inlet port is larger than outlet port. The rotation of pump is clockwise.
The swash plate is control by mean of hydarulic, but I don't know how exact it does. And the situation is:
At first, the pump done well
After, when the pressure is about 50 bar, oil has gone to tank by drain line.not go in the outlet line of the pump. So the pressure gradual decrease.
Please help me to tell the name, code of the pump.And what problem with my pump. Thanks you very much.
Re: what is name,code of the pump
11/17/2010 8:28 AM
I think you're going to have to do a little paint stripping and cleaning. There should at least be some kind of number stamped into the body. This will give you a starting point. Don't forget the bottom. You may have to use a mirror to get a visual.
Is that writing on the round piece in the center right of first picture?
If you can find the manufacturer of the entire unit, they should be able to help with pump identification and parts.
Re: What is Name, Code of the Pump
11/17/2010 9:50 AM
Can you get a closer look at this region of the 2nd photo?
11/18/2010 12:04 AM
This appears as 'Rotary Piston, Axial - Swash Plate Pump'.
The shown pump appears to be much use up, right? Hope this problem should have developed recently or from the commissioning? Or after any maintenance activity?
These type of pumps have 'hydraulically activated swash plate'. The tilt of swash plate would result in adjusting/varying the flow from zero to max.
You have indicated, "After, when the pressure is about 50 bar, oil has gone to tank by drain line. not go in the outlet line of the pump. So the pressure gradually decreases". This leads to suspect the mal-operation of the hydraulic system meant for swash plate operation. Unintentionally if the swash plate is tilted to zero angle, the out put also will be zero.
11/18/2010 12:57 AM
Dear ,
I have some experience of this type of pump,as i understand there may be -
1. Improper clearance between plunger and its housing which leads to more oil in drain at higher pressure.
2.Swash plate may not be lapped properly which leads to oil leakage from there , as you may be knowing whenever plunger makes forward movement, there is some oil leakage from the plunger end to the swash plate which lubricate the swash plate, but if lapping is not perfect ,then chances of oil leak in more quantity in drain possible.
3.There may be problem with pressure controlling devise which leads to higher oil leak at higher pressure, but this will be clear as swept volume indicator will show higher value , may be more than 70 percent, normally when pump is healthy then it should run at 20-30 percent.
If you want any nore details ,you may contact vendor which is in this type of pump, in my knowledge M/S DENIOSON is one of the most reputed company in this field.
Thanks
Sanjay Kumar
Reliability Engineer
Qatargas
11/18/2010 8:50 PM
These types of pumps were used in car air-conditioning systems, belt driven with an electro-magnetic clutch. Used to be called swash plate pumps or rotary pumps - on account of the plate movement.
11/19/2010 7:10 PM
Thanks you very much for your answer. You are so kind for me. the information you tell me is very usefull.
I see the orther pump, but they are the same kind. and i have some information:
- i see on the house of pump the word " MUUUFK 8J3887-2-" and " UNNROU"
- This is picture of the pump
Thanks for reading.
please tell me any information you know a bout this pump.
Register to Reply 6 comments
JohnDG (1); kramarat (1); Phil D. (1); sanjayldpe (1); tendem (1); yesyen (1)
