Previous in Forum: Pipe Bend Redius Calculation   Next in Forum: What is Name, Code of the Pump
Wafer vs Lug Type Butterfly Valve
11/17/2010 6:04 AM
Where to use wafer valve and where to use lug type valve. What is the selection criteria between wafer & lug type butterfly valve.
Good Answers: 137
Re: Wafer vs Lug type butterfly valve
11/17/2010 7:34 AM
Plain wafer is cheapest. Lugged wafer has advantage that the lugs help align the valve with the flanges. Neither allows end-of-line service i.e. close the valve and remove the pipe from the "dead" side. Valve with threaded lugs allows this, but a bit more costly.
Cheers......Codey
Re: Wafer vs Lug Type Butterfly Valve
11/17/2010 12:46 PM
With a full lug body valve, you can achieve dead end service. I tend to always specify full lug body valves because I might need to isolate a section of pipe without shutting down or draining half of my system.
If this is not a concern of yours, then the wafer type valve should be cheaper.
You might also find wafer type valves used on plastic piping where metallic piping cannot be used do to corrosion. In these cases you often see metal flange rings used to clamp a wafer style valve to the belled ends of platic pipe.
Some standards are like the North Pole and some are like Mecca. People use both to get their sense of direction, however, only one is a preferred destination. - P.E. Scheibmeir
Good Answers: 137
11/17/2010 2:04 PM
Lugs can be threaded or unthreaded. Have to be threaded if you want dead end service.
Cheers........Codey
11/18/2010 9:04 AM
In Texas, when you indicate to a supply house that you want "full-lug body" valves, it is inferred that they are to be threaded.
Yes, of course, the lugs need to be threaded. Very good point.
11/18/2010 6:08 AM
Recommend blind flange on end of line service, I have never trusted butterfly valves.
EZ to install but no life IMO gate is a much better valve if exercised.
Good Answers: 137
11/18/2010 7:04 AM
That's OK if you can drain the pipes both sides of the valve, but that's often undesirable for various reasons. If you're worried about the butterfly valve you can fit a blank flange after removing the pipe on the dead side (with a threaded-lug butterfly).
Cheers........Codey
Codemaster (3); MrGeneRall (2); pipeit (1)
